- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions
- Meeting the Process Mining prerequisites
- Meeting the Integration Service requirements
- Running uipathctl
- Migration and upgrade
- Upgrading Automation Suite
- Migrating from Automation Suite on EKS/AKS to Automation Suite on OpenShift
- Monitoring and alerting
- Cluster administration
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Robot cannot connect to an Automation Suite Orchestrator instance
- Log streaming does not work in proxy setups
The Dapr installation for Process Mining requires cert-manager.
You can install cert-manager via Helm. For installation instructions, see the cert-manager documentation.
Prerequisites
Kubectl CLI (
kubectl
) installed and configured. -
Appropriate permissions to delete resources in the target namespaces.
Information required
Before proceeding, you must gather the following information:
UiPath namespace where cert-manager resources are being used.
Step-by-step uninstallation process
Delete the role bindings for cert-manager:
# Verify if the role binding exists kubectl get rolebinding -n <uipath_namespace> | grep cert-manager # If it exists, delete it kubectl delete rolebinding <role-binding-name> -n <uipath_namespace>
# Verify if the role binding exists kubectl get rolebinding -n <uipath_namespace> | grep cert-manager # If it exists, delete it kubectl delete rolebinding <role-binding-name> -n <uipath_namespace> -
Delete the cert-manager role:
# Check if the role exists kubectl get role cert-manager -n <uipath_namespace> | grep cert-manager # If it exists, delete it kubectl delete role <cert-manamger-role> -n <uipath_namespace>
# Check if the role exists kubectl get role cert-manager -n <uipath_namespace> | grep cert-manager # If it exists, delete it kubectl delete role <cert-manamger-role> -n <uipath_namespace> -
Clean up cert-manager resources in the namespace:
# Delete all certificates kubectl delete certificates.cert-manager.io --all -n <uipath_namespace> # Delete all issuers kubectl delete issuers.cert-manager.io --all -n <uipath_namespace> # Delete all clusterissuers if you created any kubectl delete clusterissuers.cert-manager.io --all
# Delete all certificates kubectl delete certificates.cert-manager.io --all -n <uipath_namespace> # Delete all issuers kubectl delete issuers.cert-manager.io --all -n <uipath_namespace> # Delete all clusterissuers if you created any kubectl delete clusterissuers.cert-manager.io --all -
Uninstall the cert-manager from cluster, delete the namespace or any residual certificate resources following steps 1, 2, and 3 for other namespaces. Also, cross verify if cert-manager is not used by any other component.
Verify remaining resources:
# Check for any remaining cert-manager resources kubectl get all -n <uipath_namespace> | grep cert-manager kubectl get crd | grep cert-manager
Troubleshooting
If certain resources cannot be deleted:
Ensure you have the necessary permissions.
Check if the resources are being used by other applications.
For resources that are stuck in Terminating state, you may need to remove finalizers.
Notes
Only uninstall cert-manager if it is not being used by other applications in your cluster.
If multiple applications depend on cert-manager, consider only removing the UiPath-specific resources.
Replace
<uipath_namespace>
with your actual UiPath namespace.
Generating the application YAML file via Bash script
You can also use the following Bash script to generate the application YAML file:
#!/bin/bash
echo "Enter the namespace of argocd applications"
read argocd_namespace
echo "Enter the name of uipath namespace"
read uipath_namespace
if [[ "${argocd_namespace}" == "openshift-gitops" ]]; then
echo "Enter the argocd project name"
read project
else
project="default"
fi
echo "Enter the registry fqdn"
read registry_fqdn
echo "Enter the DAPR helm chart version"
read dapr_version
echo "-------------------- SUMMARY --------------------"
echo "Argocd Application namespace : $argocd_namespace"
echo "Uipath namespace : $uipath_namespace"
echo "Argocd Project name : $project"
echo "Helm registry FQDN : $registry_fqdn"
echo "DAPR Version : $dapr_version"
echo "------------- Application yaml file-------------"
echo -n "apiVersion: argoproj.io/v1alpha1
kind: Application
metadata:
namespace: $argocd_namespace
spec:
destination:
namespace: $uipath_namespace
server: https://kubernetes.default.svc
ignoreDifferences:
- jsonPointers:
- /data
- /stringData
- /metadata
kind: Secret
- group: apiextensions.k8s.io
jsonPointers:
- /spec/conversion
kind: CustomResourceDefinition
- group: admissionregistration.k8s.io
jsonPointers:
- /webhooks
kind: MutatingWebhookConfiguration
project: $project
source:
chart: helm/dapr
helm:
valueFiles:
- values.yaml
values: |
global:
registry: $registry_fqdn/daprio
imagePullSecrets: uipathpullsecret
mtls:
enabled: true
prometheus:
enabled: false
logAsJson: true
actors:
enabled: false
ha:
enabled: false
replicaCount: 1
rbac:
namespaced: true
seccompProfile: RuntimeDefault
dapr_dashboard:
enabled: false
dapr_operator:
watchInterval: 1m
resources:
requests:
cpu: 100m
memory: 100Mi
limits:
cpu: "1"
memory: 200Mi
watchNamespace: $uipath_namespace
deploymentAnnotations:
sidecar.istio.io/inject: "false"
dapr_sidecar_injector:
allowedServiceAccounts: $uipath_namespace:default
resources:
requests:
cpu: 100m
memory: 30Mi
limits:
cpu: "1"
memory: 100Mi
sidecarDropALLCapabilities: true
dapr_sentry:
resources:
requests:
cpu: 100m
memory: 30Mi
limits:
cpu: "1"
memory: 100Mi
dapr_rbac:
secretReader:
enabled: false
createClusterScopedObjects: true
repoURL: $registry_fqdn
targetRevision: $dapr_version
syncPolicy:
automated:
prune: true
selfHeal: true
retry:
backoff:
duration: 10s
factor: 2
maxDuration: 1m
limit: 1000
syncOptions:
- CreateNamespace=true
- RespectIgnoreDifferences=true"
#!/bin/bash
read project
else
project="default"
fi
read registry_fqdn
read dapr_version
kind: Application
metadata:
spec:
destination:
ignoreDifferences:
- jsonPointers:
- /data
- /stringData
- /metadata
kind: Secret
jsonPointers:
- /spec/conversion
jsonPointers:
- /webhooks
project: $project
source:
chart: helm/dapr
helm:
valueFiles:
- values.yaml
values: |
global:
mtls:
enabled: true
prometheus:
enabled: false
logAsJson: true
actors:
enabled: false
ha:
enabled: false
replicaCount: 1
rbac:
namespaced: true
dapr_dashboard:
enabled: false
dapr_operator:
watchInterval: 1m
resources:
requests:
cpu: 100m
memory: 100Mi
limits:
cpu: "1"
memory: 200Mi
resources:
requests:
cpu: 100m
memory: 30Mi
limits:
cpu: "1"
memory: 100Mi
dapr_sentry:
resources:
requests:
cpu: 100m
memory: 30Mi
limits:
cpu: "1"
memory: 100Mi
dapr_rbac:
secretReader:
enabled: false
syncPolicy:
automated:
prune: true
selfHeal: true
retry:
backoff:
duration: 10s
factor: 2
maxDuration: 1m
limit: 1000
syncOptions:
Prerequisites
Kubectl CLI (
kubectl
UiPath namespace where Dapr is installed.
ArgoCD namespace (typically
argocd
oropenshift-gitops
Delete the Dapr application from ArgoCD:
# Verify the application exists first kubectl get application.argoproj.io dapr -n <argocd_namespace> # If it exists, delete it kubectl delete application.argoproj.io dapr -n <argocd_namespace>
# Verify the application exists first kubectl get application.argoproj.io dapr -n <argocd_namespace> # If it exists, delete it kubectl delete application.argoproj.io dapr -n <argocd_namespace>Wait for resources to be deleted.
Delete Dapr custom resources:
# Delete all Dapr components in the UiPath namespace kubectl delete components.dapr.io --all -n <uipath_namespace> # Delete all Dapr configurations in the UiPath namespace kubectl delete configurations.dapr.io --all -n <uipath_namespace> # Delete all Dapr resiliencies in the UiPath namespace kubectl delete resiliencies.dapr.io --all -n <uipath_namespace> # Delete all Dapr subscriptions in the UiPath namespace kubectl delete subscriptions.dapr.io --all -n <uipath_namespace>
# Delete all Dapr components in the UiPath namespace kubectl delete components.dapr.io --all -n <uipath_namespace> # Delete all Dapr configurations in the UiPath namespace kubectl delete configurations.dapr.io --all -n <uipath_namespace> # Delete all Dapr resiliencies in the UiPath namespace kubectl delete resiliencies.dapr.io --all -n <uipath_namespace> # Delete all Dapr subscriptions in the UiPath namespace kubectl delete subscriptions.dapr.io --all -n <uipath_namespace> -
Delete Dapr custom resource definitions (CRDs):
# Delete Dapr CRDs kubectl delete crd components.dapr.io kubectl delete crd configurations.dapr.io kubectl delete crd resiliencies.dapr.io kubectl delete crd subscriptions.dapr.io
# Delete Dapr CRDs kubectl delete crd components.dapr.io kubectl delete crd configurations.dapr.io kubectl delete crd resiliencies.dapr.io kubectl delete crd subscriptions.dapr.io -
Remove Dapr webhook configurations:
# Delete the Dapr sidecar injector webhook kubectl delete mutatingwebhookconfigurations dapr-sidecar-injector
# Delete the Dapr sidecar injector webhook kubectl delete mutatingwebhookconfigurations dapr-sidecar-injector -
Remove Dapr-specific role bindings
# Verify if the role binding exists kubectl get rolebinding -n <uipath_namespace> | grep dapr # If it exists, delete dapr specific role binding kubectl delete rolebinding <dapr-role-binding> -n <uipath_namespace>
# Verify if the role binding exists kubectl get rolebinding -n <uipath_namespace> | grep dapr # If it exists, delete dapr specific role binding kubectl delete rolebinding <dapr-role-binding> -n <uipath_namespace> -
Remove Dapr-specific roles:
# Check if the dapr-creator role exists kubectl get role -n <uipath_namespace> | grep dapr # If it exists, delete dapr specific rolekubectl delete role <dapr-role> -n <uipath_namespace>
# Check if the dapr-creator role exists kubectl get role -n <uipath_namespace> | grep dapr # If it exists, delete dapr specific rolekubectl delete role <dapr-role> -n <uipath_namespace> -
Clean up remaining Dapr resources
Pods:
# List all Dapr-related pods kubectl get pods -n <uipath_namespace> | grep dapr # Delete each Dapr pod if any kubectl delete pod <pod_name> -n <uipath_namespace>
# List all Dapr-related pods kubectl get pods -n <uipath_namespace> | grep dapr # Delete each Dapr pod if any kubectl delete pod <pod_name> -n <uipath_namespace> -
Services:
# List all Dapr-related services kubectl get svc -n <uipath_namespace> | grep dapr # Delete each Dapr service if any kubectl delete svc <service_name> -n <uipath_namespace>
# List all Dapr-related services kubectl get svc -n <uipath_namespace> | grep dapr # Delete each Dapr service if any kubectl delete svc <service_name> -n <uipath_namespace> -
Deployments:
# List all Dapr-related deployments kubectl get deployments -n <uipath_namespace> | grep dapr # Delete each Dapr deployment kubectl delete deployment <deployment_name> -n <uipath_namespace>
Verification
After completing all the uninstallation steps, verify that all Dapr components have been removed:
# Check for any remaining Dapr resources
kubectl get crd | grep dapr
Troubleshooting
Check if the resources are being managed by another controller.
Investigate any dependencies that might be preventing deletion.
Notes
Replace
<uipath_namespace>
with your actual UiPath namespace. -
Replace
<argocd_namespace>
with your actual ArgoCD namespace. -
Be cautious when deleting shared resources that might affect other applications.
- Installing cert-manager
- Uninstalling Cert Manager
- Prerequisites
- Information required
- Step-by-step uninstallation process
- Troubleshooting
- Notes
- Installing Dapr
- Generating the application YAML file via Bash script
- Uninstalling Dapr
- Prerequisites
- Verification
- Troubleshooting
- Notes
