Last updated Oct 15, 2025
Prerequisites at a glance
The following table lists the main hardware and software requirements for deploying Automation Suite on EKS/AKS .
ComponentPrerequisites
Cluster
AKS or EKS cluster
Minimum node capacity8 vCPU and 16 GB RAM
Total cluster capacitySee Capacity planning.
Cache
Redis
Registry
OCI-compliant registry required in offline installations
SQL Server
  • Microsoft SQL Server 2017, 2019, and 2022; Standard and Enterprise editions
  • 8 (v-)CPU
  • 32 GB RAM
  • 256 GB SSD
Storage
  • Objectstore - Azure Blob, AWS S3, S3-compaMBle Objectstore
  • Block storage (StorageClass with replication for the Persistent Volume)
  • File system (StorageClass for workloads that do not require replication)
  • Azure Queue Storage/SQS (required for Integration Service)
NetworkingNetwork policies, VNETs / VPCs, DNS, subnets, NSGs / security groups, NAT gateway, elastic IP and internet gateway
TLS
1.2 or 1.3
CertificatesThe certificate for the FQDN to access Automation Suite
ProxyOnly required for proxy configurations
