- Overview
- Requirements
- Pre-installation
- Migration and upgrade
- Upgrading Automation Suite
- Migrating from Automation Suite on EKS/AKS to Automation Suite on OpenShift
- Monitoring and alerting
- Cluster administration
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Robot cannot connect to an Automation Suite Orchestrator instance
- Log streaming does not work in proxy setups
Last updated Oct 15, 2025
Automation Suite lets you manage your self-hosted UiPath® platform as one product. However, not all of our self-hosted products are part of Automation Suite.
The following products are part of the Automation Suite bundle. You have the ability to enable or disable products at any time after their installation.
- Action Center (Actions and Processes)
- AI Center (AI Center connected to an external Orchestrator not supported)
- Apps
- Automation Hub
- Automation Ops
- Data Service
- Document Understanding
- Insights
- Integration Service
- Orchestrator
- Process Mining
- Studio Web
- Task Mining
- Test Manager
Some Automation Suite products have additional dependencies on each other, as listed in the following table:
Product | Dependency |
AI Computer Vision |
Apps |
Automation Hub |
Automation Suite Robots |
Document Understanding |
Integration Service |
Process Mining |
Studio Web |
Task Mining |
* Running Studio Web without Automation Suite Robots is possible but not recommended, as the experience of using Studio Web will be affected.
