Last updated Oct 15, 2025
Other troubleshooting
Velero backup fails with FailedValidation error
When attempting to run a scheduled backup in Automation Suite on EKS/AKS, Velero may return the following error:
Phase: FailedValidation
Validation errors: an existing backup storage location was not specified at backup creation time and the server default default does not exist.
Error: BackupStorageLocation.velero.io "default" not foundPhase: FailedValidation
This occurs due to the default-bs1 BackupStorageLocation not being marked as default in the Velero configuration.
To address the issue, take the following steps:
  1. Verify the backup storage locations configured for Velero:
    kubectl get backupstoragelocations -n velerokubectl get backupstoragelocations -n velero
    Confirm whether the DEFAULT column is empty.
  2. Edit the backup storage location to set the default value:
    kubectl edit backupstoragelocation default-bs1 -n velerokubectl edit backupstoragelocation default-bs1 -n velero
  3. Under the spec section, add the following line:
    default: truedefault: true
  4. Save the changes.
  5. Restart the Velero pods to apply the configuration:
    kubectl delete pod -n velero --allkubectl delete pod -n velero --all
    Alternatively, perform a rolling restart:
    kubectl -n velero rollout restart deploy/velerokubectl -n velero rollout restart deploy/velero
  6. Verify the fix:
    Confirm that the PHASE is Available and the DEFAULT column shows Yes.
Accessing FQDN returns RBAC: access denied error
Accessing an FQDN may return the following error:
RBAC: access deniedRBAC: access denied
This issue occurs because the FQDN and its relevant URL access are routed via Istio. Istio relies on a WASM plugin to route the request to the appropriate destination pod.
If the WASM plugin image is missing in the registry, internal or external, Istio blocks the URL access and returns a RBAC: access denied error.
Solution
To address this issue, you must ensure that the registry is hydrated and the WASM plugin image exists in registry.
To check the WASM plugin image, run teh folowing command:
kubectl get wasmplugin -A -o yaml | grep urlkubectl get wasmplugin -A -o yaml | grep url
The output will be similar to the one from the following example:
url: oci://testing.azurecr.io/istio-wasm-plugin:2024.10.3url: oci://testing.azurecr.io/istio-wasm-plugin:2024.10.3
In the example above, the WASM plugin image is istio-wasm-plugin:2024.10.3. You must check if this image is present in your registry or not.
  • Velero backup fails with FailedValidation error
  • Accessing FQDN returns RBAC: access denied error
  • Description
  • Solution
