- Overview
- Requirements
- Pre-installation
- Migration and upgrade
- Upgrading Automation Suite
- Migrating from Automation Suite on EKS/AKS to Automation Suite on OpenShift
- Monitoring and alerting
- Cluster administration
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Robot cannot connect to an Automation Suite Orchestrator instance
- Log streaming does not work in proxy setups
- Velero backup fails with FailedValidation error
- Accessing FQDN returns RBAC: access denied error
You can bring your own Kubernetes cluster and follow your standard practices to provision and manage it.
Install and configure the Istio service mesh. For details, see Installing and configuring the service mesh.
Bring your own ArgoCD. For details, see Installing and configuring the GitOps tool.
If you install Process Mining, you must install cert-manager and Dapr yourself. For details, see Meeting the Process Mining prerequisites.
Create and manage certificates yourself. For details, see Certificates generated during installation.
Create a service account and grant the necessary permissions for the Automation Suite installation. For details, see Granting installation permissions.
After installing the required components, you can execute the installer with lower permissions. For the list of required permissions, see Granting installation permissions.
Each Automation Suite Long-Term Support release comes with a compatibility matrix. For compatible EKS or AKS versions, see Compatibility matrix.
We tested Automation Suite compatibility with the following Linux OSes:
| Cloud provider | OS |
| AKS |
| EKS |
To estimate node capacity based on your product and scale requirements, use the UiPath Automation Suite Install Sizing Calculator.
The root volume requirement for agent (worker) nodes is 256 GB.
At a minimum, to start with the mandatory platform services (Identity, licensing, and routing) and Orchestrator, you must provision 8 vCPU and 16 GB RAM per node.
We do not recommend using spot instances in Automation Suite in production scenarios, due to stability and performance issues.
You must disable swap memory before installing Automation Suite. Swap memory is known to cause issues with container workloads. Additionally, Automation Suite workloads do not benefit from using swap memory, and Kubernetes already optimizes memory usage.
We recommend enabling autoscaling on your cluster to ensure high reliability and to avoid business interruptions.
If you install Task Mining, you must provision additional worker node(s) with 20 vCPU and 60 GB RAM. This node must be tainted to ensure only Task Mining workloads run on it. For details, see the Node scheduling section.
Automation Suite Robots require additional worker node(s).
The hardware requirements for the Automation Suite Robots node depend on the way you plan to use your resources. In addition to the additional agent node requirements, you also need a minimum of 10 GB of file storage to enable package caching.
For details, see Storage documentation.
The following sections describe the factors that impact the amount of hardware the Automation Suite Robots node requires.
Robot size
The following table describes the required CPU, memory, and storage for all robot sizes.
Size |
CPU |
Memory |
Storage |
Small |
0.5 |
1 GB |
1 GB |
Standard |
1 |
2 GB |
2 GB |
Medium |
2 |
4 GB |
4 GB |
Large |
6 |
10 GB |
10 GB |
Agent node size
The resources of the Automation Suite Robots agent node have an impact on the number of jobs that can be run concurrently. The reason is that the number of CPU cores and the amount of RAM capacity are divided by the CPU/memory requirements of the job.
For example, a node with 16 CPUs and 32 GB of RAM would be able to run any of the following:
- 32 Small jobs
- 16 Standard jobs
- 8 Medium jobs
- 2 Large jobs
Job sizes can be mixed, so at any given moment, the same node could run a combination of jobs, such as the following:
- 10 Small jobs (consuming 5 CPUs and 10 GB of memory)
- 4 Standard jobs (consuming 4 CPUs and 8 GB of memory)
- 3 Medium jobs (consuming 6 CPUs and 12 GB of memory)
Kubernetes resource consumption
Given that the node is part of a Kubernetes cluster, the Kubernetes agent present on the server (kubelet) consumes a small amount of resources. Based on our measurements, the kubelet consumes the following resources:
- 0.6 CPU
- 0.4 GB RAM
A node similar to the one previously described would actually have approximately 15.4 CPUs and 31.6 GB of RAM.
Automatic machine size selection
All your cross-platform processes have the Automation Suite Robots option set to Automatic by default. This setting selects the appropriate machine size for running the process using serverless robots.
When automatically choosing the size, the criteria listed in the below table are evaluated in order. As soon as one criterion is satisfied, the corresponding machine size is chosen and the remaining criteria are not evaluated.
Order |
Criterion |
Machine size |
1 |
Remote debugging job |
Medium |
2 |
Process depends on UI Automation OR Process depends on the UiPath Document Understanding activities |
Standard |
3 |
Other unattended process |
Small |
For increased performance, you can install Document Understanding on an additional agent node with GPU support. Note, however, that AI Center-based projects in Document Understanding are fully functional without the GPU node. Actually, Document Understanding uses CPU VMs for all its extraction and classification tasks, while for OCR we strongly recommend the usage of a GPU VM.
For more details about the CPU/GPU usage within the Document Understanding framework, refer to CPU and GPU Usage.
If you want to use an additional node with GPU support, you must meet the following requirements:
Hardware |
Minimum requirement |
Processor |
8 (v-)CPU/cores |
RAM |
52 GB |
OS disk |
256 GB SSD Min IOPS: 1100 |
Data disk |
N/A |
GPU RAM |
11 GB |
--node-taints nvidia.com/gpu=present:NoSchedule instead of --node-taints sku=gpu:NoSchedule.
tolerations block. You can use the following example:tolerations:
- key: "nvidia.com/gpu"
operator: "Equal"
value: "present"
effect: "NoSchedule"tolerations:
operator: "Equal"
value: "present"
effect: "NoSchedule"Automation Suite supports NVIDIA GPUs. To learn about how to configure NVDIA GPUs (such as drivers), please refer to the respective docs from Azure or AWS.
Additional Document Understanding modern projects requirements
enable_cpu_inference property to true, as indicated in
the Enabling or disabling Document Understanding
section.
- Inference may be up to 10 times slower.
- We recommend using it for documents with a maximum of 125 pages. No active limitation is in place. However, inference might fail for documents larger than 125 pages.
Without CPU inference, a minimum of 5 GPUs is required for Document Understanding modern projects. The example scenario in the following table demonstrates how 5 GPUs is enough to process 300 pages.
| Function | Number |
| Custom model pages processed per hour | 300 |
| Out of the box model pages processed per hour | 0 |
| Models training in parallel | 1 |
| Number of pages in all projects - Design time | 200 |
| Number of document types per project version | 3 |
The 5 GPUs are distributed amongst different functions, as detailed in the following table:
| Service | Number of GPUs |
| OCR replicas | 1 |
| Custom model training replicas | 1 |
| Custom model replicas | 2 |
| Out of the box model replicas | 1 |
| Total | 5 |
For more information on how to allocate GPUs to each service, check the Allocating GPU resources for Document Understanding modern projects page.
In addition to the GPU demands, Document Understanding modern projects also require specific CPU resources for optimal performance. For optimal performance, a minimum of 18 vCPUs is required.
objectstore is required to perform the activities from the provided examples continuously for one year. You can start with a smaller
number, but the activity will fail once the storage is complete, unless you explicitly scale it.
If you are provisioning for one year of continuous processing, you will need 4 TB for Document Understanding modern projects and 512 GB for the other products. The total will be 4.5 TB of storage. Similarly, if you start with six months of processing, you will need 2 TB for Document Understanding modern projects and 512 GB for the other products. In this case the total will be 2.5 TB.
Provisioning MIG-enabled GPUs
Automation Suite Document Understanding workloads support running on Virtual GPUs (VGPUs) created with NVIDIA MIG (Multi-Instance GPU) technology.
To run Document Understanding in these conditions, keep in mind the following requirements:
GPU memory (VRAM): at least 16 GB per VGPU
Note: UiPath only support the single strategy, meaning that all VGPUs will be exactly the same. -
Storage: at least 80 GB per VGPU
Enabling MIG-enabled GPUs in Kubernetes
After provisioning the MIG enabled GPUs in your cluster with profiles matching or exceeding the above minimum requirements, ensure that the GPUs are schedulable Kubernetes. The node must report a non-zero number of GPUs before workloads can be scheduled on it.
To make the GPUs schedulable, you have two options:
- Option A: Follow the official GPU setup documentation of your cloud provider:
- Option B
(Alternative): Deploy the NVIDIA device plugin directly:
- Create a new namespace:
kubectl create namespace gpu-resourceskubectl create namespace gpu-resources - Apply the following configuration, replacing
migEnabledPoolNamewith the label that matches your GPU node:apiVersion: v1 kind: Pod metadata: name: nvidia-device-plugin-pod namespace: gpu-resources spec: affinity: nodeAffinity: requiredDuringSchedulingIgnoredDuringExecution: nodeSelectorTerms: - matchExpressions: - key: agentpool operator: In values: # To be changed to a selector that matches the GPU nodes - migEnabledPoolName containers: - args: - --fail-on-init-error=false env: - name: MPS_ROOT value: /run/nvidia/mps - name: MIG_STRATEGY # We only support the single strategy for now value: single - name: NVIDIA_MIG_MONITOR_DEVICES value: all - name: NVIDIA_VISIBLE_DEVICES value: all - name: NVIDIA_DRIVER_CAPABILITIES value: compute,utility image: nvcr.io/nvidia/k8s-device-plugin:v0.17.3 imagePullPolicy: IfNotPresent name: nvidia-device-plugin-ctr securityContext: allowPrivilegeEscalation: true capabilities: add: - SYS_ADMIN terminationMessagePath: /dev/termination-log terminationMessagePolicy: File volumeMounts: - mountPath: /var/lib/kubelet/device-plugins name: device-plugin tolerations: - key: CriticalAddonsOnly operator: Exists - effect: NoSchedule key: nvidia.com/gpu operator: Exists terminationGracePeriodSeconds: 30 volumes: - hostPath: path: /var/lib/kubelet/device-plugins type: "" name: device-pluginapiVersion: v1 kind: Pod metadata: name: nvidia-device-plugin-pod namespace: gpu-resources spec: affinity: nodeAffinity: requiredDuringSchedulingIgnoredDuringExecution: nodeSelectorTerms: - matchExpressions: - key: agentpool operator: In values: # To be changed to a selector that matches the GPU nodes - migEnabledPoolName containers: - args: - --fail-on-init-error=false env: - name: MPS_ROOT value: /run/nvidia/mps - name: MIG_STRATEGY # We only support the single strategy for now value: single - name: NVIDIA_MIG_MONITOR_DEVICES value: all - name: NVIDIA_VISIBLE_DEVICES value: all - name: NVIDIA_DRIVER_CAPABILITIES value: compute,utility image: nvcr.io/nvidia/k8s-device-plugin:v0.17.3 imagePullPolicy: IfNotPresent name: nvidia-device-plugin-ctr securityContext: allowPrivilegeEscalation: true capabilities: add: - SYS_ADMIN terminationMessagePath: /dev/termination-log terminationMessagePolicy: File volumeMounts: - mountPath: /var/lib/kubelet/device-plugins name: device-plugin tolerations: - key: CriticalAddonsOnly operator: Exists - effect: NoSchedule key: nvidia.com/gpu operator: Exists terminationGracePeriodSeconds: 30 volumes: - hostPath: path: /var/lib/kubelet/device-plugins type: "" name: device-plugin
nvidia.com/gpu, based on the MIG
profile you configured. The node should now be schedulable and ready to run Document
Understanding workloads.
We recommend enabling node taints on dedicated worker nodes for Task Mining, Automation Suite Robots, and Document Understanding.
AI Center and DU example:
For CPU:
kubectl taint node <node_name> aic.ml/cpu=present:NoSchedulekubectl taint node <node_name> aic.ml/cpu=present:NoSchedule
For GPU:
kubectl taint node <node_name> nvidia.com/gpu=present:NoSchedulekubectl taint node <node_name> nvidia.com/gpu=present:NoSchedule
Task Mining example:
kubectl taint node <node_name> task.mining/cpu=present:NoSchedulekubectl taint node <node_name> task.mining/cpu=present:NoScheduleAutomation Suite Robots example:
add a taint for serverless robots using the following command:
kubectl taint node <node_name> serverless.robot=present:NoSchedulekubectl taint node <node_name> serverless.robot=present:NoSchedule -
add the labels for serverless robots using the following command:
kubectl label node <node_name> serverless.robot=true serverless.daemon=truekubectl label node <node_name> serverless.robot=true serverless.daemon=true
If you have custom node taints that are enforced by Gatekeeper Policy, such as specific roles for worker nodes or labels, they will not be passed to Automation Suite and may interrupt the installation process.
To learn about taints and tolerations, see Kubernetes documentation.
- Cluster and permissions
- Supported EKS/AKS versions
- Node capacity
- Swap memory
- Autoscaling
- Additional Task Mining requirements
- Additional Automation Suite Robots requirements
- Robot size
- Agent node size
- Kubernetes resource consumption
- Automatic machine size selection
- Additional Document Understanding recommendations
- Additional Document Understanding modern projects requirements
- Provisioning MIG-enabled GPUs
- Node scheduling
