- Overview
- Requirements
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Troubleshooting
- How to enable Istio logging
- Redis Probe Failure
- RKE2 Server Fails to Start
- Exploring Logs
OUT OF SUPPORT
Last updated Feb 24, 2025
The following issues can happen if you install RHEL 8.4 and are performing the offline installation, which requires podman. These issues are specific to podman and the OS being installed together.
you cannot install both of the following on the cluster:
podman-1.0.0-8.git921f98f.module+el8.3.0+10171+12421f43.x86_64podman-3.0.1-6.module+el8.4.0+10607+f4da7515.x86_64
- package
cockpit-podman-29-2.module+el8.4.0+10607+f4da7515.noarchrequirespodman>=1.3.0, but none of the providers can be installed - cannot install the best candidate for the job
- problem with installed package
- package
podman-3.0.1-6.module+el8.4.0+10607+f4da7515.x86_64requirescontainernetworking-plugins>=0.8.1-1, but none of the providers can be installed -
you cannot install both of the following:
containernetworking-plugins-0.7.4-4.git9ebe139.module+el8.3.0+10171+12421f43.x86_64containernetworking-plugins-0.9.1-1.module+el8.4.0+10607+f4da7515.x86_64
- package
podman-catatonit-3.0.1-6.module+el8.4.0+10607+f4da7515.x86_64requirespodman=3.0.1-6.module+el8.4.0+10607+f4da7515, but none of the providers can be installed - cannot install the best candidate for the job
podman-catatonit-3.0.1-6.module+el8.4.0+10607+f4da7515.x86_64(try to add--allowerasingto command line to replace conflicting packages or--skip-brokento skip uninstallable packages or--nobestto use not only best candidate packages)
