- Overview
- Requirements
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Troubleshooting
- How to enable Istio logging
- Redis Probe Failure
- RKE2 Server Fails to Start
- Exploring Logs
OUT OF SUPPORT
Last updated Feb 24, 2025
linkDescription
linkThis log could be found when using Kerberos for SQL access, and SQL connection is failing inside services. Similarly, you
may see
kinit: Client's credentials have been revoked while getting initial credential
in one of the following job names: services-preinstall-validations-job
, kerberos-jobs-trigger
, kerberos-tgt-update
Solution
linkThis could be caused by the AD user account used to generate the keytab being disabled. Re-enabling the AD user account should fix the issue.
