- Overview
- Requirements
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Troubleshooting
- How to enable Istio logging
- Redis Probe Failure
- RKE2 Server Fails to Start
- Exploring Logs
This is one of two ways in which you can migrate your standalone Orchestrator to Automation Suite. In addition to Orchestrator, this method helps you migrate other products and services. For more information, see Migration options.
The full migration option ensures high fidelity data transfer between the standalone product databases and the automatically created Automation Suite databases. If you do not want to use the default Automation Suite databases, you can opt for your own migrated databases provided that you update their connection strings.
We have organized the migration tasks as a checklist, and you can tick each checkbox as you complete tasks to keep track of your progress. However, the ticks are lost if you refresh the page.
You can also download the migration checklist as an Excel spreadsheet.
To migrate from a standalone deployment to Automation Suite, take the following steps:
Phase |
Description |
Instructions |
1 |
Upgrade standalone deployment |
2 |
Deploy Automation Suite |
3 |
Follow pre-migration steps |
4 |
Back up the databases |
5 |
Restore the databases |
6 |
Update database connection strings |
Update the database connection strings for the restored databases via ArgoCD. Details... |
7 |
Follow post-migration steps |
