- Overview
- Requirements
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Troubleshooting
- How to enable Istio logging
- Redis Probe Failure
- RKE2 Server Fails to Start
- Exploring Logs
OUT OF SUPPORT
Last updated Feb 24, 2025
If you run an offline installation, you typically need a larger disk size due to the offline artifacts that are used.
Once the installation completes, you can remove the local artifacts. Failure to do so can result in unnecessary disk pressure during cluster operations.
On the primary server, where the installation was performed, you can perform a cleanup using the following commands.
Remove all images loaded by podman into the local container storage using the following command.:
podman image rm -af
podman image rm -af -
Then remove the temporary offline folder, used with the flag
--offline-tmp-folder
. This parameter defaults to/tmp
:rm -rf /path/to/temp/folder
