- Overview
- Requirements
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Troubleshooting
- How to enable Istio logging
- Redis Probe Failure
- RKE2 Server Fails to Start
- Exploring Logs
OUT OF SUPPORT
Last updated Feb 24, 2025
Online Single-node Evaluation Mode
linkPreparation
link- Make sure that there is enough disk space on the node. For more details, see Hardware requirements.
- Download and unzip the new installer (
installer.zip
) on the server.- Connect to the machine using SSH.
If you set a password, the command is as follows:
ssh <user>@<dns_of_vm>
If you used an SSH key, the command is as follows:
ssh -i <path/to/Key.pem> <user>@<dns_of_vm>
- Become root:
sudo su -
sudo su - - Move to home directory:
cd ~
cd ~ - Download the installation package. Make sure to keep the
(single quotes) around the download URL.wget 'https://download.uipath.com/automation-suite/installer.zip' -O installer.zip
wget 'https://download.uipath.com/automation-suite/installer.zip' -O installer.zip - Create an installation folder and unzip the installation package:
mkdir /opt/UiPathAutomationSuite/<installer-folder> -R unzip ./installer.zip -d /opt/UiPathAutomationSuite/<installer-folder>
mkdir /opt/UiPathAutomationSuite/<installer-folder> -R unzip ./installer.zip -d /opt/UiPathAutomationSuite/<installer-folder> - Give proper permissions to the folder by running the following command:
sudo chmod 755 -R /opt/UiPathAutomationSuite/<installer-folder>
- Make the original
cluster_config.json
file available on the server. - Generate the new
cluster_config.json
file as follows:-
If you have the old
cluster_config.json
, use the following command to generate the configuration file from the cluster:cd /path/to/new-installer ./configureUiPathAS.sh config get -i /path/to/old/cluster_config.json -o /path/to/store/generated/cluster_config.json
If you do not have the old
cluster_config.json
file, run the following command:cd /path/to/new-installer ./configureUiPathAS.sh config get -o /path/to/store/generated/cluster_config.json
Note: For details on how to configure thecluster_config.json
parameters, see Advanced installation experience. -
Execution
linkMaintenance and Backup
- Make sure you enabled the backup on the cluster. For details, see Backing up and restoring the cluster.
- Connect to the server node via SSH.
- Verify that all desired volumes have backups in the cluster by running the following command:
/path/to/new-installer/configureUiPathAS.sh verify-volumes-backup
/path/to/new-installer/configureUiPathAS.sh verify-volumes-backupNote: The backup might take some time, so wait for approximately 15-20 minutes, and then verify the volumes backup again. - To verify if Automation Suite is healthy, run:
kubectl get applications -n argocd
kubectl get applications -n argocd - Put the cluster in maintenance mode as follows:
- Execute the following command:
/path/to/new-installer/configureUiPathAS.sh enable-maintenance-mode
/path/to/new-installer/configureUiPathAS.sh enable-maintenance-mode - Verify that the cluster is in maintenance mode by running the following command:
/path/to/new-installer/configureUiPathAS.sh is-maintenance-enabled
- Make an SQL database backup.
Upgrade Infrastructure and Services on Servers
- Connect to the server via SSH.
- Become root by running
sudo su -
. - Upgrade the infrastructure and servers by running the following command:
/path/to/new-installer/install-uipath.sh --upgrade -k -f -s -i /path/to/cluster_config.json --accept-license-agreement -o /path/to/output.json
/path/to/new-installer/install-uipath.sh --upgrade -k -f -s -i /path/to/cluster_config.json --accept-license-agreement -o /path/to/output.jsonNote: This command disables the maintenance mode that you enabled before the upgrade because all services are required to be up during the upgrade. The command also creates a backup of the cluster state and pauses all other scheduled backups. - After the successful upgrade and verification, resume the backup scheduling on the node by running the following command:
/path/to/new-installer/configureUiPathAS.sh resume-scheduled-backups
Rollback on Error
linkPreparation
- Create a separate folder to store older bundles, and perform the following operations inside that folder.
- Download and unzip the installer of the older version (
installer.zip
) on the node.Note: Give proper permissions to the folder by runningsudo chmod 755 -R <installer-folder>
. - Create a
restore.json
file and copy it to all the nodes. For details, see Backing up and restoring the cluster. - Verify that the etcd backup data is present on the primary server at the following location:
/mnt/backup/backup/<etcdBackupPath>/<node-name>/snapshots
.etcdBackupPath
- this is the same as the one specified inbackup.json
while enabling the backup'snode-name
;node-name
- the hostname of the primary server VM.
Cluster Cleanup
- Copy and run the dedicated script to uninstall everything from that node. Do this for all the nodes. For details, see Troubleshooting.
- Restore all UiPath databases to the backup created before the upgrade.
Restore Infra on Server Nodes
- Restore infra by running the following command:
/path/to/older-installer/install-uipath.sh -i /path/to/restore.json -o /path/to/output.json -r --accept-license-agreement --install-type online
Restore Volumes Data
- Go to the new installer folder.Note: The previous infra restore commands were executed using the old installer, and the following commands are executed using the new installer bundle.
- Disable the maintenance mode on the cluster by running the following command:
/path/to/new-installer/configureUiPathAS.sh disable-maintenance-mode
/path/to/new-installer/configureUiPathAS.sh disable-maintenance-mode - Verify that maintenance mode is disabled by running the following command:
/path/to/new-installer/configureUiPathAS.sh is-maintenance-enabled - Copy the
restore.json
file that was used in the infra restore stage to the new installer bundle folder. - Restore volumes by running the following command from the newer installer bundle:
/path/to/new-installer/install-uipath.sh -i /path/to/new-installer/restore.json -o /path/to/new-installer/output.json -r --volume-restore --accept-license-agreement --install-type online
/path/to/new-installer/install-uipath.sh -i /path/to/new-installer/restore.json -o /path/to/new-installer/output.json -r --volume-restore --accept-license-agreement --install-type online - Once the restore is completed, verify if everything is restored and working properly.
- During the upgrade, scheduled backups were disabled on the primary node. To enable them again, run the following command:
