- Overview
- Requirements
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Troubleshooting
- How to enable Istio logging
- Redis Probe Failure
- RKE2 Server Fails to Start
- Exploring Logs
Each cloud template deployment automatically provisions a set of components based on the provided inputs. To check out the list of components for each cloud provider, see the following:
To calculate the cost of the infrastructure provisioned by the cloud templates based on your scenario needs, refer to the following guidelines and estimates.
There are multiple factors impacting the cost of the infrastructure deployed by the cloud templates, such as the following:
- Number of server nodes
- Server node instance type
- Number of agent nodes
- Number of GPU nodes
- GPU node instance type
- Products selected
You can accurately estimate the cost of your cloud infrastructure by taking the following steps:
- Determine the resources required by your scenario using the UiPath Automation Suite Install Sizing Calculator.
Use the pricing calculator for the public cloud that you currently use:
To help you get started with the pricing calculators, refer to the following examples.
The following table describes the multi-node HA-ready production infrastructure cost estimate for the Basic and Complete profiles in the context of the previously introduced guidelines.
The estimates do not account for the load balancers, Bastion, key vault, and backup.
Preset hardware configuration |
Number of server nodes |
AWS |
Azure |
3 | |||
3 |
