- Overview
- Requirements
- Q&A: Deployment Templates
- GCP Deployment Architecture
- Step 1: Preparing the GCP Deployment
- Step 2: Deploying Automation Suite to GCP
- Step 3: Post-deployment Steps
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Troubleshooting
- How to enable Istio logging
- Redis Probe Failure
- RKE2 Server Fails to Start
- Exploring Logs
This page describes the steps you need to take to deploy Automation Suite in GCP.
Once you prepare the GCP environment, you can directly deploy the infrastructure.
Take the following steps:
Deployment Parameters
Name |
Description |
Parameter type |
Example |
Project in which the resources will be deployed. |
string |
Region where the resources will be deployed. |
string |
Default zone where zonal resources are deployed. The zone should belong to the region you chose. |
string |
Automation Suite installer version. |
string |
Automation Suite installer URL. It overwrites the
installer_version parameter and installs the version from the package.
string |
Automatically install Automation Suite on the provided infrastructure. |
bool |
Fully qualified domain name (FQDN) for Automation Suite. |
string |
Username used to log in VMs via SSH. |
string |
Path to the SSH public key used to access VMs. |
string |
Path to the SSH private key used to access VMs. |
string |
Instance type of server machines. |
string |
Instance type of agent machines. |
string |
(Optional) Parameter used only if the number of GPU agents is at least 1. Instance type of GPU agent machines. |
string |
(Optional) Parameter used only if the number of GPU agents is at least 1. GPU type for the GPU nodes. |
string |
Number of server VMs, must be odd |
number |
Number of agent VMs. |
number |
Number of GPU agent VMs |
number |
(Optional) Name of the custom image you want to use for the VM's. Leave empty to default to latest RHEL 8 GCP image. |
string |
Install AI Center. |
bool |
Install Document Understanding. |
bool |
Install Insights. |
bool |
Install Test Manager. |
bool |
Install Automation Ops. |
bool |
Install Automation Hub. |
bool |
Install Apps. |
bool |
Install Action Center. |
bool |
Install Task Mining. |
bool |
By setting the parameter as true, you agree to the applicable license agreement. |
bool |
If you want to add any new configuration that is exposed via cluster_config.json, follow these steps:
