- Overview
- Pre-installation
- Cluster administration
- uipathctl cluster
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl version
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- Troubleshooting
uipathctl reference guide
Last updated Feb 24, 2025
Enable the periodical snapshot backup of the cluster.
uipathctl snapshot backup enable [flags]uipathctl snapshot backup enable [flags]-h, --help help for enable
-p, --prefix string This will prefix the names of all the snapshot backups with the given string.
This is only used if you wish to enable schedule backup.
The default value is snapshot
(default "snapshot")
-r, --retention string Retention policy in duration format Hh:Mm:Ss, for e.g 8h5m1s.
Default value of 168h.
(default "168h")
--schedule string Unix cron expression for schedule
this is only required if you wish to enable schedule backup.
Default value "*/45 * * * *" denotes every 45th minutes backup is triggered.
(default "*/45 * * * *") -h, --help help for enable
(default "168h")
(default "*/45 * * * *")--context string name of the kubeconfig context to use
--timeout duration timeout of the command (default 1h0m0s) --context string name of the kubeconfig context to use
