- Overview
- Pre-installation
- uipathctl prereq
- uipathctl prereq create
- uipathctl prereq run
- Cluster administration
- uipathctl cluster
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl version
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- Troubleshooting
uipathctl reference guide
Last updated Feb 24, 2025
--excluded strings components to be excluded from execution, defaults to none
-h, --help help for prereq
--included strings components to be included in the execution, defaults to all--excluded strings components to be excluded from execution, defaults to none
--included strings components to be included in the execution, defaults to all--context string name of the kubeconfig context to use
--timeout duration timeout of the command (default 1h0m0s)--context string name of the kubeconfig context to use
