uipathctl reference guide
Last updated Feb 24, 2025
uipathctl config saml-certificates rotate
Rotate exchanges the current SAML data with the future one.
The command defaults to the current context in the kubeconfig file. If the --kubeconfig flag is set, it uses the kubeconfig file specified by the flag.
uipathctl config saml-certificates rotate [flags]uipathctl config saml-certificates rotate [flags]
Examples
# Rotate the saml certificates from the cluster
        uipathctl identity rotate-saml-certificates
        # Rotate the saml certificates from the cluster identified by the current context in the kubeconfig file
        uipathctl identity rotate-saml-certificates --kubeconfig cluster.kubeconfig        # Rotate the saml certificates from the cluster
Options
-h, --help   help for rotate  -h, --help   help for rotate
      --timeout duration    timeout of the command (default 1h0m0s)      --context string      name of the kubeconfig context to use
  • Description
  • Examples
  • Options
  • Options inherited from parent commands
