- Overview
- Pre-installation
- Cluster administration
- uipathctl cluster
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl version
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- Troubleshooting
- uipathctl health
- uipathctl health bundle
- uipathctl health check
- uipathctl health diagnose
- uipathctl health test
uipathctl reference guide
Last updated Feb 24, 2025
Generate a support bundle that you can use to troubleshoot Automation Suite issues.
uipathctl health bundle [PATH] [flags]uipathctl health bundle [PATH] [flags]
# Generate the bundle in the OS temporary directory
uipathctl health bundle input.json
# Generate the bundle in a specific directory
uipathctl health bundle input.json/cluster_config.json --output-dir /foo/bar
# Generate the bundle without additional health/prereq report
uipathctl health bundle input.json/cluster_config.json --skip-diagnose
-h, --help help for bundle
-p, --include-previous If false, skips printing the logs for the previous instance of the container in a pod if it exists. (default true)
--limit-bytes int Maximum bytes of logs to return. Defaults to no limit.
--output-dir string path to output directory
--since-time string Only return logs after a specific date (RFC3339). Defaults to all logs.
--skip-diagnose skip additional health/prereq report
--versions string path to versions file -h, --help help for bundle
--versions string path to versions file--context string name of the kubeconfig context to use
--excluded strings components to be excluded from execution, defaults to none
--included strings components to be included in the execution, defaults to all
-o, --output output output format. one of [json,yaml,text,junit] (default text)
--timeout duration timeout of the command (default 1h0m0s)--context string name of the kubeconfig context to use
