uipathctl reference guide
Last updated Feb 24, 2025
uipathctl config alerts
Configure alert of email type.
uipathctl config alerts [flags]uipathctl config alerts [flags]
Options
  -h, --help   help for alerts  -h, --help   help for alerts
--timeout duration    timeout of the command (default 1h0m0s)--context string      name of the kubeconfig context to use
  • Description
  • Options
  • Options inherited from parent commands
