- Overview
- Pre-installation
- Cluster administration
- uipathctl cluster
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl version
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- Troubleshooting
uipathctl reference guide
Last updated Feb 24, 2025
Enable basic auth enables basic sign-in for the provided organization.
kubeconfig file. If the --kubeconfig flag is set, it uses the kubeconfig file specified by the flag.
uipathctl config enable-basic-auth [flags]uipathctl config enable-basic-auth [flags] # Enable basic auth for the provided organization in cluster
uipathctl config enable-basic-auth --orgname organization
# Enable basic auth for the provided organization in the cluster identified by the current context in the kubeconfig file
uipathctl config enable-basic-auth --orgname organization --kubeconfig cluster.kubeconfig # Enable basic auth for the provided organization in cluster
uipathctl config enable-basic-auth --orgname organization --kubeconfig cluster.kubeconfig -h, --help help for enable-basic-auth
--orgname string organization name -h, --help help for enable-basic-auth
--orgname string organization name --context string name of the kubeconfig context to use
--timeout duration timeout of the command (default 1h0m0s) --context string name of the kubeconfig context to use
