uipathctl reference guide
Last updated Feb 24, 2025
uipathctl cluster migration run
The following command executes the cluster migration from a source cluster to a target cluster.
There are two stages of the migration process:
  1. Kubernetes objects are migrated from the source cluster, followed by the installation on the target cluster.
  2. The input and version files are used to configure the migration process.
uipathctl cluster migration run [PATH] [flags]uipathctl cluster migration run [PATH] [flags]
Examples
# Migrate from source cluster to target cluster, using input.json/cluster_config.json as the target cluster configuration
        uipathctl cluster migration run input.json/cluster_config.json --versions versions.json --target-kubeconfig <path> --target-kubecontext <context>        # Migrate from source cluster to target cluster, using input.json/cluster_config.json as the target cluster configuration
Options
-h, --help                       help for run
      --skip-outbound-data         skip outbound data migration
      --skip-pre-reqs              skip prerequisite checks for data migration
      --target-context string      name of kubeconfig context to use for target cluster
      --target-kubeconfig string   target cluster kubectl configuration file
      --versions string            path to versions file  -h, --help                       help for run
      --timeout duration    timeout of the command (default 1h0m0s)      --context string      name of the kubeconfig context to use
  • Description
  • Examples
  • Options
  • Options inherited from parent commands
