OUT OF SUPPORT
uipathctl reference guide
Last updated Apr 29, 2025
uipathctl sso
Manage SSO for fabric components.
uipathctl sso [flags]uipathctl sso [flags]
Options
-h, --help   help for sso  -h, --help   help for sso
--timeout duration    timeout of the command (default 1h0m0s)--context string      name of the kubeconfig context to use
  • Description
  • Options
  • Options inherited from parent commands
