OUT OF SUPPORT
uipathctl reference guide
Last updated Apr 29, 2025
uipathctl cluster maintenance
Perform maintenance operations on the cluster.
uipathctl cluster maintenance [flags]uipathctl cluster maintenance [flags]
Examples
    # Enable maintenance mode for the cluster
	uipathctl cluster maintenance enable
	# Disable maintenance mode for the cluster
	uipathctl cluster maintenance disable
	# Check if the cluster is in maintenance mode
	uipathctl cluster maintenance is-enabled    # Enable maintenance mode for the cluster
Options
  -h, --help   help for maintenance  -h, --help   help for maintenance
  • Description
  • Examples
  • Options
  • Options inherited from parent commands
