- Overview
- Pre-installation
- Cluster administration
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- uipathctl sso
- uipathctl sso generate-connector
- uipathctl sso generate-overlays
- uipathctl sso generate-rbac
- uipathctl identity enable-basic-auth
- Monitoring and alerting
- Troubleshooting
OUT OF SUPPORT
uipathctl reference guide
Last updated Apr 29, 2025
Enable basic authentication for the provided organization. The command defaults to the current context in the
kubeconfig file. If the --kubeconfig flag is set, it uses the kubeconfig file specified by the flag.
# Enable basic auth for the provided organization in cluster
uipathctl identity enable-basic-auth --orgname organization
# Enable basic auth for the provided organization in the cluster identified by the current context in the kubeconfig file
uipathctl identity enable-basic-auth --orgname organization --kubeconfig cluster.kubeconfig
-h, --help help for enable-basic-auth
--orgname string organization name -h, --help help for enable-basic-auth
--orgname string organization name--context string name of the kubeconfig context to use
--timeout duration timeout of the command (default 1h0m0s)--context string name of the kubeconfig context to use
