OUT OF SUPPORT
uipathctl reference guide
Last updated Apr 29, 2025
uipathctl cluster upgrade
Load the configuration found at the path provided in the argument and drive the state of the cluster to it.
The command will perform a diff between the current state of the cluster and the desired state, and apply the changes to the cluster.
Unlike the apply command, the upgrade command will not install any component that is not already installed.
When the --override flag is present, the list will override the selection found in the input file. The flag is mutually exclusive with the --only flag. When the exclude_components key is present in the input file, the components found in the list are excluded from the installed components. This has the highest priority over all the other flags and it is not mutually exclusive with any of them.
uipathctl cluster upgrade PATH [flags]uipathctl cluster upgrade PATH [flags]
Examples
# Apply the configuration found in input.json, using the versions found in versions.json
        uipathctl cluster upgrade input.json --versions versions.json
        # Apply the configuration and specify the kubeconfig file to use
        uipathctl cluster upgrade input.json --kubeconfig cluster.kubeconfig --versions versions.json
        # Apply the configuration but skip the components installed directly by helm
        uipathctl cluster upgrade --skip-helm input.json --versions versions.json
        # Apply the configuration overriding the initial list of components
        uipathctl cluster upgrade --override automation_hub,orchestrator --versions versions.json
Options
-h, --help               help for upgrade
--no-wait            if true, return immediately after the ArgoCD applications are created
--only strings       optional exclusive list of components to apply
--override strings   optional list to override the components enabled in input.json file
--skip-helm          if true, skip components installed directly by helm
--versions string    path to versions file  -h, --help               help for upgrade
--timeout duration    timeout of the command (default 1h0m0s)--context string      name of the kubeconfig context to use
  • Description
  • Examples
  • Options
  • Options inherited from parent commands
