OUT OF SUPPORT
uipathctl reference guide
Last updated Apr 29, 2025
uipathctl identity update-token-signing-certificate
Update the future token signing certificate with the certificate and key provided as arguments.
If the provided key is encrypted, set the --password flag specifying the decryption password. The command defaults to the current context in the kubeconfig file. If the --kubeconfig flag is set, it uses the kubeconfig file specified by the flag.
uipathctl identity update-token-signing-certificate [flags]uipathctl identity update-token-signing-certificate [flags]
Examples
# Update the token signing certificate with the provided certificate path and key path from the cluster
        uipathctl identity update-token-signing-certificate --cert server.crt --key server.key
        # Update the token signing certificate with the provided certificate path and encrypted key path from the cluster
        uipathctl identity update-token-signing-certificate --cert server.crt --key server.key --password password
        # Update the token signing certificate with the provided certificate path and key path from the cluster identified by the current context in the kubeconfig file
        uipathctl identity update-token-signing-certificate --cert server.crt --key server.key --kubeconfig cluster.kubeconfig
Options
--cert string       path to certificate
  -h, --help              help for update-token-signing-certificate
--key string        path to certificate key
--password string   password for encrypted key--cert string       path to certificate
--timeout duration    timeout of the command (default 1h0m0s)--context string      name of the kubeconfig context to use
  • Description
  • Examples
  • Options
  • Options inherited from parent commands
