- Overview
- Pre-installation
- Cluster administration
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- Troubleshooting
OUT OF SUPPORT
uipathctl reference guide
Last updated Apr 29, 2025
Update the custom configuration of the Orchestrator component.
The command defaults to the current context in the
kubeconfig
file. If the --kubeconfig
flag is set, it will use the kubeconfig
file specified by the flag.
uipathctl config orchestrator update-config [flags]
# Update orchestrator nlog configuration from the cluster
uipathctl config orchestrator update-config --nlog-config nlog.custom.json
# Update orchestrator app settings configuration from the cluster
uipathctl config orchestrator update-config --app-settings appsettings.custom.json
# Update orchestrator nlog configuration from the cluster identified by the current context in the kubeconfig file
uipathctl config orchestrator update-config --nlog-config nlog.custom.json --kubeconfig cluster.kubeconfig
--app-settings string path to application settings config file in json format
-h, --help help for update-config
--nlog-config string path to nlog config file in json format
