- Overview
- Pre-installation
- Cluster administration
- uipathctl cluster
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl config generate
- uipathctl config kubeconfig
- uipathctl config products
- uipathctl config products scale-down
- uipathctl config products scale-up
- uipathctl registry
- uipathctl registry cleanup
- uipathctl registry hydrate-temp-registry
- uipathctl registry seed
- uipathctl registry seed-internal-registry
- uipathctl registry uninstall
- uipathctl registry upload
- uipathctl registry validate
- uipathctl rke2
- uipathctl rke2 disk
- uipathctl rke2 update-fqdn
- uipathctl rke2 gpu
- uipathctl rke2 node
- uipathctl rke2 node remove
- uipathctl rke2 objectstore
- uipathctl rke2 objectstore uninstall
- uipathctl rke2 registry
- uipathctl version
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- uipathctl config kerberos-auth
- uipathctl config kerberos-auth global-config
- uipathctl config kerberos-auth global-config update
- uipathctl config kerberos-auth service-config
- uipathctl config kerberos-auth service-config update
- uipathctl config windows-auth
- uipathctl config windows-auth update
- Monitoring and alerting
- uipathctl config
- uipathctl config alerts
- uipathctl config telemetry
- uipathctl config telemetry get
- uipathctl config telemetry set
- uipathctl resource
- uipathctl resource constraint-report
- uipathctl resource report
- uipathctl service
- uipathctl service aicenter
- uipathctl service aicenter configure
- Troubleshooting
uipathctl reference guide
Last updated Apr 28, 2025
Update the custom configuration of the Orchestrator component.
The command defaults to the current context in the
kubeconfig
file. If the --kubeconfig
flag is set, it will use the kubeconfig
file specified by the flag.
uipathctl config orchestrator update-config [flags]
# Update orchestrator nlog configuration from the cluster
uipathctl config orchestrator update-config --nlog-config nlog.custom.json
# Update orchestrator app settings configuration from the cluster
uipathctl config orchestrator update-config --app-settings appsettings.custom.json
# Update orchestrator nlog configuration from the cluster identified by the current context in the kubeconfig file
uipathctl config orchestrator update-config --nlog-config nlog.custom.json --kubeconfig cluster.kubeconfig
--app-settings string path to application settings config file in json format
-h, --help help for update-config
--namespace string The namespace where UiPath Automation Suite is deployed (default "uipath")
--nlog-config string path to nlog config file in json format
--timeout duration timeout of the command (default 5h0m0s)
