uipathctl reference guide
Last updated Apr 28, 2025
uipathctl registry validate
Validate the docker registry.
uipathctl registry validate [flags]uipathctl registry validate [flags]
Options
-h, --help              help for validate
      --manifest string   path to docker image manifest  -h, --help              help for validate
      --versions string     optional path to versions file      --context string      name of the kubeconfig context to use
  • Description
  • Options
  • Options inherited from parent commands
