uipathctl reference guide
Last updated Apr 28, 2025
uipathctl rke2 registry
Hydrate the docker registries
uipathctl rke2 registry [flags]uipathctl rke2 registry [flags]
Options
-h, --help   help for registry -h, --help   help for registry
      --versions string     optional path to versions file      --context string      name of the kubeconfig context to use
  • uipathctl rke2 registry
  • Description
  • Options
  • Options inherited from parent commands
