- Overview
- About uipathctl
- uipathctl reference documentation
- Pre-installation
- Cluster administration
- uipathctl cluster
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl version
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- Troubleshooting
About uipathctl
uipathctl reference guide
Last updated Feb 24, 2025
About uipathctl
uipathctl
is a UiPath® command-line tool that allows you to perform various operations in Automation Suite on EKS/AKS and Automation Suite on Linux.
You can use uipathctl to check prerequisites in your environment, install Automation Suite, as well as configure and manage it from a single unified CLI.
Note, however, that not all commands referenced in this guide are suitable for both Automation Suite on EKS/AKS and Automation Suite on Linux. If certain commands are exclusive to one Automation Suite flavor, they should be marked accordingly.
It is important to be aware of the specific naming conventions we employ for the Automation Suite configuration file. The
input.json
name is used for Automation Suite on EKS/AKS, whereas cluster_config.json
is specific to Automation Suite on Linux only.
For more information, including a complete list of
uipathctl
operations, see the uipathctl reference documentation.
You can install
uipathctl
on the Linux, macOS, and Windows platforms.
Note:
Currently,
uipathctl
is only compatible with the x86 architecture.
You cannot run uipathctl
on machines based on the ARM architecture,
such as Macs with Apple Silicon (M series) CPUs.
