uipathctl reference guide
Last updated Feb 24, 2025
uipathctl health check
Check the health of the deployment using the Kubernetes API. This command only performs tests that do not mutate the cluster.
uipathctl health check [flags]uipathctl health check [flags]
Examples
# Get the health of the cluster
Options
-h, --help   help for check  -h, --help   help for check
-h, --help help for check-h, --help help for check
  • Description
  • Examples
  • Options
  • Options inherited from parent commands
