uipathctl reference guide
Last updated Feb 24, 2025
uipathctl manifest get
Get prints on stdout the current manifest observed in the cluster. The format is always YAML.
The command will default to the current context in the kubeconfig file. If the --kubeconfig flag is set, it will use the kubeconfig file specified by the flag. Without other flags, the cluster wide configurations and dependencies are not included in the output.
uipathctl manifest get [flags]uipathctl manifest get [flags]
Examples
# Get the current manifest observed in the cluster, without dependencies or cluster wide configurations
        # Get the current manifest from the cluster identified by the current context in the kubeconfig file
        uipathctl manifest get --kubeconfig /root/kubeconfig
        # Get the current manifest, including the cluster wide configurations and the dependencies
        uipathctl manifest get --include-config --include-dependencies
Options
-h, --help                   help for get
      --ignore-errors          ignore errors when getting the manifest
      --include-config         include cluster wide config in the diff
      --include-dependencies   include dependencies in the diff
  -o, --output output          output format. one of [json,yaml] (default yaml)  -h, --help                   help for get
      --timeout duration    timeout of the command (default 1h0m0s)      --context string      name of the kubeconfig context to use
  • uipathctl manifest get
  • Description
  • Examples
  • Options
  • Options inherited from parent commands
