- Overview
- Pre-installation
- Cluster administration- uipathctl cluster
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl version
- Backup and restore- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management- uipathctl config additional-ca-certificates
- Upgrade
- Authentication
- Monitoring and alerting
- Troubleshooting
uipathctl reference guide
Last updated Feb 24, 2025
Update the future Token Signing certificate providing the
               pfx and key as arguments.
               If the provided key is encrypted, use the
               --password flag specifying the decryption password.
               The command defaults to the current context in the
               kubeconfig file. If the --kubeconfig flag is set, it uses the kubeconfig file specified by the flag.
               uipathctl config token-signing-certificates update [flags]uipathctl config token-signing-certificates update [flags]# Update the token signing certificate with the provided certificate path and key path from the cluster
uipathctl config token-signing-certificates update --cert server.crt --key server.key
# Update the token signing certificate with the provided certificate path and encrypted key path from the cluster
uipathctl config token-signing-certificates update --cert server.crt --key server.key --password password
# Update the token signing certificate with the provided certificate path and key path from the cluster identified by the current context in the kubeconfig file
uipathctl config token-signing-certificates update --cert server.crt --key server.key --kubeconfig cluster.kubeconfig
# Update the token signing certificate with the provided pfx certificate
uipathctl config tls-certificates update --pfx-cert certificate.pfx --password password# Update the token signing certificate with the provided certificate path and key path from the cluster
uipathctl config tls-certificates update --pfx-cert certificate.pfx --password password--cert string        path to certificate
  -h, --help               help for update
      --key string         path to certificate key
      --namespace string   The namespace where UiPath Automation Suite is deployed (default "uipath")
      --password string    password for encrypted key
      --pfx-cert string    path to certificate in pfx format      --cert string        path to certificate
      --pfx-cert string    path to certificate in pfx format--context string      name of the kubeconfig context to use
      --versions string     optional path to versions file      --context string      name of the kubeconfig context to use
