- Overview
- Pre-installation
- Cluster administration
- uipathctl cluster
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl version
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- Troubleshooting
uipathctl reference guide
Last updated Feb 24, 2025
Back up the snapshot of the cluster.
NAME denotes the name associated with the snapshot backup.
uipathctl snapshot backup create NAME [flags]uipathctl snapshot backup create NAME [flags]-h, --help help for create
-w, --wait wait until the backup completes (default false) -h, --help help for create
-w, --wait wait until the backup completes (default false)--context string name of the kubeconfig context to use
--timeout duration timeout of the command (default 1h0m0s)--context string name of the kubeconfig context to use
