- Overview
- Pre-installation
- Cluster administration
- uipathctl cluster
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl version
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- Troubleshooting
- uipathctl health
- uipathctl health bundle
- uipathctl health check
- uipathctl health diagnose
- uipathctl health test
uipathctl reference guide
Last updated Feb 24, 2025
Diagnose the last unsuccessful sync operation using the Kubernetes API.
uipathctl health diagnose PATH [flags]uipathctl health diagnose PATH [flags]
# Diagnose the last unsuccessful sync operation
uipathctl health diagnose input.json
-h, --help help for diagnose
--versions string path to versions file -h, --help help for diagnose
--versions string path to versions file--context string name of the kubeconfig context to use
--excluded strings components to be excluded from execution, defaults to none
--included strings components to be included in the execution, defaults to all
-o, --output output output format. one of [json,yaml,text,junit] (default text)
--timeout duration timeout of the command (default 1h0m0s)--context string name of the kubeconfig context to use
