- Overview
- Pre-installation
- Cluster administration
- uipathctl cluster
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl version
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- Troubleshooting
uipathctl reference guide
Last updated Feb 24, 2025
The following command generates a sample RBAC configuration file for ArgoCD. SeeRBAC Configuration - Argo CD - Declarative GitOps CD for Kubernetes.
uipathctl config argocd generate-rbac [flags]uipathctl config argocd generate-rbac [flags]
# Generate a sample rbac configuration file for ArgoCD:
uipathctl config generate-rbac generate-rbac# Generate a sample rbac configuration file for ArgoCD:
uipathctl config generate-rbac generate-rbac--context string name of the kubeconfig context to use
--timeout duration timeout of the command (default 1h0m0s) --context string name of the kubeconfig context to use
