- Release notes
- Before you begin
- Getting started
- Integrations
- Managing access
- Working with process apps
- Creating apps
- Loading data
- Uploading data
- Setting up a SQL Server account for data upload using an extractor
- Loading data using Theobald Xtract Universal
- Customizing process apps
- Data transformations
- TemplateOne app template
- Purchase to Pay app template
- Order to Cash app template
- Basic troubleshooting guide
Process Mining
When you have received additional roles, you must refresh the Process Mining portal page to access the functions that are available for the new role or roles. For example, when you are a Business user and you now have Developer and/or Administrator rights, you must refresh the Process Mining portal page to see the Admin Console tab.
Similarly, you still may see any functions you cannot use anymore after a role has been revoked, until you refresh the Process Mining portal page.
When you have enabled the Process Mining service for your tenant the Process Mining option is available in your UiPath Automation Suite Portal. When you click on the Process Mining option in the menu, the Process Mining portal is displayed. Initially, the Process Mining portal displays a welcome message and does not contain any process apps. See the illustration below.
Based on your permissions, you can create new process apps, or published process apps will be made available for you. These will be displayed in the Process Mining portal. See the illustration below for an example.
Below is a description of the elements in the Process Mining portal.
Tab | Description |
Process apps tab |
The Process apps tab is the starting point for business users to analyze data using published process apps, and for app developers to create and publish process apps. |
Published process apps |
You can click on the |
All process apps |
Note that the All process apps panel is only visible if you have the Developer role assigned. |
Admin Console |
Note that the Admin Console tab is only visible if you have the Administrator role assigned. |
Create New App Button
The Create new app button enables you to create a new process app. See Create new app wizard.
Process App Properties
Below is a description of the properties of a process app displayed in the All process apps list.
Property |
Description |
Name |
The name of the process app. |
ID |
The ID of the process app. You need this ID to upload the data for the process app. |
Application status |
The current status of the process app.
Note:
You can click on View log to see the log details. See also Viewing Ingestion Logs. |
Status changed |
The date on which the status was last changed. |
Last successful run |
The date on which the data was last updated successfully. |
Actions menu |
Several icons that enable you to perform actions on process apps. |
When hovering over a row in the All process apps list, the actions for the process app are displayed.
Action |
Name |
Description |
Edit application |
Enables you to customize the process app to your business needs. See Working with the dashboard editor. Note:
The Edit application button is only visible when you have the permission to edit the process app. |
More |
Enables you to open a context menu with the following options:
See the illustration below. Note:
Depending on your permissions for the process app, options can be disabled. |
By default, Name, Applications status, Status changed, and Last successful run are displayed for the process apps listed. Follow these steps to change the visible columns.
- Click on
to display the list of columns.
- Select the columns you want to display in the All process apps list.
You can click on Reset to reset the visible columns to the default selection.
