Process Mining
Last updated Nov 6, 2025
Loading Data Using DataBridgeAgent
Important:
DataBridgeAgent is only needed if you are migrating from an on-premises stand-alone Process Mining version.
Only use DataBridgeAgent if you have a custom .mvp connector. Otherwise, use CData Sync, Theobald Xtract Universal for SAP, or files to upload data.
Important:
Always make sure that the data is in the required input format for the app template. See App Templates. This can be done either in the Data transformations, or by renaming the output fields of the on-premises standalone connector (.mvp).
© 2005-2026 UiPath. All rights reserved.
