- Release notes
- Before you begin
- Getting started
- Integrations
- Managing access
- Working with process apps
- Creating apps
- Loading data
- Uploading data
- Setting up a SQL Server account for data upload using an extractor
- Loading data using Theobald Xtract Universal
- Customizing process apps
- Data transformations
- TemplateOne app template
- Purchase to Pay app template
- Order to Cash app template
- Basic troubleshooting guide
Process Mining
2023.4.1
linkAddendum: July 12, 2023
linkNew app templates available
The following app templates are now available for download on the UiPath Customer Portal:
SAP-Accounts-Payable
- SAP-Ariba-Vendor-Sourcing
See App Templates and Uploading app templates.
DataBridgeAgent
A new version of the DataBridgeAgent is now available.
Release date: June 27, 2023
linkWe are constantly working to improve your UiPath Process Mining experience. Even though there are no major significant changes with this release, we made sure to bring security improvements and minor bug fixes to our product.
What is new
linkManaged Kubernetes Services
You can now install Process Mining via Automation Suite on Azure Kubernetes Service (AKS) and Amazon Elastic Kubernetes Service (EKS). Automation Suite on EKS/AKS allows you to bring your own Kubernetes cluster, dedicated for Automation Suite and managed by you. See the Automation Suite on EKS/AKS release notes.
Maximum number of activities
When uploading a dataset with too many activities, Process Mining may become unresponsive. A warning message is now displayed when you try to upload a dataset that contains more than 500 activities.
Upgrade reminder for process apps
With the introduction of TRACY in Process Mining 2023.4, all new process apps will use TRACY for the process graph layout. Existing process apps will continue to work in Process Mining 2023.4.1, but will show a banner or a warning message to indicate that the layout is no longer supported.
