- Release notes
- Before you begin
- Getting started
- Integrations
- Managing access
- Working with process apps
- Creating apps
- Loading data
- Uploading data
- Setting up a SQL Server account for data upload using an extractor
- Loading data using Theobald Xtract Universal
- Customizing process apps
- Data transformations
- TemplateOne app template
- Purchase to Pay app template
- Order to Cash app template
- Basic troubleshooting guide
Process Mining
Last updated Apr 15, 2025
Introduction
linkSimilar to extracting data and preparing a dataset for use in a Process Mining on-premises (standalone) Discovery Accelerator, you must extract data from the source system and create a dataset for use in Process Mining on-premises (Automation Suite). This page describes how you can extract data from your source system for use in Process Mining (Automation Suite) using DataBridgeAgent.DataBridgeAgent is used to extract data from the source system, and exports
.tsv
files. These .tsv
files are loaded into the Microsoft SQL Server database using CData Sync. See the illustration below for an overview of the
data flow.
Important:
Only use DataBridgeAgent if you have a custom
.mvp
connector. Otherwise, use CData Sync, Theobald Xtract Universal for SAP, or files to upload data.
