- Release notes
 - Before you begin
 - Getting started
 - Integrations
 - Managing access
 - Working with process apps
 - Creating apps
 - Loading data
- Uploading data
 - Setting up a SQL Server account for data upload using an extractor
 - Loading data using Theobald Xtract Universal
 - DataBridgeAgent
 - Setup credentials for the SQL Server database
 - Extracting data from an SAP source system
 - Extracting data via loading .csv files
 - Extracting data via an ODBC connection
 - Using a credential store
- System requirements
 - Configuring DataBridgeAgent
 - Configuring CData Sync
 - Using DataBridgeAgent with SAP Connector for Purchase-to-Pay Discovery Accelerator
 - Using DataBridgeAgent Wwith SAP Connector for Order-to-Cash Discovery Accelerator
 - Customizing process apps
 - Data transformations
 - TemplateOne app template
 - Purchase to Pay app template
 - Order to Cash app template
 - Basic troubleshooting guide
Process Mining
Last updated Apr 15, 2025
If you want to use data directly from your SAP system in Automation Suite you must set up the SAP extraction before you can use DataBridgeAgent. See Set up Native SAP Extraction for a detailed description.
