- Release notes
- Before you begin
- Getting started
- Integrations
- Managing access
- Working with process apps
- Creating apps
- Loading data
- Uploading data
- Setting up a SQL Server account for data upload using an extractor
- Loading data using Theobald Xtract Universal
- DataBridgeAgent
- Setup credentials for the SQL Server database
- Extracting data from an SAP source system
- Extracting data via loading .csv files
- Extracting data via an ODBC connection
- Using a credential store
- System requirements
- Configuring DataBridgeAgent
- Configuring CData Sync
- Using DataBridgeAgent with SAP Connector for Purchase-to-Pay Discovery Accelerator
- Using DataBridgeAgent Wwith SAP Connector for Order-to-Cash Discovery Accelerator
- Customizing process apps
- Data transformations
- TemplateOne app template
- Purchase to Pay app template
- Order to Cash app template
- Basic troubleshooting guide
Process Mining
Last updated Apr 15, 2025
linkIf you want to use data from an external data source via an ODBC connection, make sure that the required ODBC driver is installed on the server.
Important: All databases that have a 64-bit version can be accessed using an ODBC connection. The required 64-bit ODBC driver must be
installed on the UiPath Process Mining server, and the server must be able to access that specific system.
