- Overview
- Requirements
- Q&A: Deployment templates
- Release notes
- GCP deployment architecture
- Step 1: Preparing the GCP deployment
- Step 2: Deploying Automation Suite to GCP
- Step 3: Post-deployment steps
- Configuring the machines
- Configuring the external objectstore
- Configuring an external Docker registry
- Configuring the load balancer
- Configuring the DNS
- Configuring Microsoft SQL Server
- Configuring the certificates
- Online multi-node HA-ready production installation
- Offline multi-node HA-ready production installation
- Disaster recovery - Installing the secondary cluster
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- GPU node affected by resource unavailability
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Issues accessing the ArgoCD read-only account
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- Exploring Logs
Before performing an Automation Suite GCP deployment, you need to ensure you meet the requirements and plan accordingly.
To prevent data loss, ensure the infrastructure you use does not automatically delete cluster disks on cluster reboot or shutdown. If this capability is enabled, make sure to disable it.
By default, GCP supports only the latest RHEL 8 version. Moreover, it performs automatic updates that may lead to a minor OS version upgrade. As a consequence, you can fall out of the supported Automation Suite OS versions. To mitigate this we recommend using a custom image.
API requirements
You must have access to a GCP project with the default service account enabled.
This project needs the following APIs enabled, and you must have permissions for all the operations the APIs imply:
- Compute Engine API
- Cloud DNS API
- Cloud SQL Admin API
- Secret Manager API
- Cloud Resource Manager API
- Service Networking API
- Identity and Access Management (IAM) API
To enable an API, take the following steps:
Search for the API in the top search bar.
On the Compute Engine API page, select Enable.
Note: If you plan to use service account credentials for the deployment, you must enable the Identity and Access Management (IAM) API. The API is used to get the default Compute Engine service account that will be linked to the deployed VMs.
GCP software requirements
You must have GCP SDK and Terraform installed on your machine.
For installation details, see the following:
RSA key pair prerequisites
You need an RSA key pair used for accessing the cluster. You can generate one using the following command:
ssh-keygen -t rsa -b 4096 -C "<ssh_user>"
The deployment provisions a configurable number of VMs with configurable types. Additionally, the templates also deploy VMs needed for node registration traffic. Those VMs have a fixed instance type.
Each project has a quota for the number of cores anyone can provision for a specific region.
If the deployment requirements put you over this quota, the deployment would fail. To prevent this, make sure you have enough room in the quota for your Automation Suite deployment.
Make sure that the VM family region availability meets your requirements.
You can check what VM instances are available in a region at Regions and zones.
Ensure that the GPU you want to use and the region you are deploying satisfy these constraints and the instance type for the GPU nodes supports a GPU. As stated in the GCP documentation, GPUs are currently only supported with general-purpose N1 or accelerator-optimized A2 machine types.
You can check GCP and RHEL documentation to create a custom image. An alternative is to use Daisy and the workflows provided by GCP.
To avoid automatic updates, you can tie the OS to a specific update using the following command:
subscription-manager release --set=<version>
