- Overview
- Requirements
- Q&A: Deployment templates
- Configuring the machines
- Configuring the external objectstore
- Configuring an external Docker registry
- Configuring the load balancer
- Configuring the DNS
- Configuring Microsoft SQL Server
- Configuring the certificates
- Online multi-node HA-ready production installation
- Offline multi-node HA-ready production installation
- Disaster recovery - Installing the secondary cluster
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Using the Orchestrator Configurator Tool
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- GPU node affected by resource unavailability
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Issues accessing the ArgoCD read-only account
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- Exploring Logs
Last updated Dec 23, 2025
The Orchestrator Configurator Tool is a bash script that allows you to place files and settings inside the Orchestrator deployment
in Automation Suite. The tool helps you add storage files, credential store plugins, NLog extensions, new NLog configurations,
and override
appSettings.
The environment where you use the Orchestrator Configurator Tool must be able to run a bash script and have the following tools:
- kubectl configured with a connection to the cluster
- jq 1.6
rclone
Note: Follow these steps to install rclone.
Important:
Do not download and use the ArgoCD CLI tool independently. To maintain compatibility and ensure smooth operation, we recommend using the ArgoCD we bundle within the Automation Suite artifacts. To do that, you must add ArgoCD to your path from the latest installer by running the following command:
export PATH="$PATH:/opt/UiPathAutomationSuite/<version>/installer/bin"export PATH="$PATH:/opt/UiPathAutomationSuite/<version>/installer/bin"To be able to run Orchestrator Configurator Tool from any location, follow these steps:
Example:
Usage: ./orchestrator_configurator.sh \
-s blobstoragefolder -p pluginsfolder -n nlogextensionsfolder \
-c appsettings.json -l nlog.custom.config
-c|--app-settings
application configuration file containing json with key-value structure
-l|--nlog-config-file
nlog config file, json
-s|--storage-folder
location of the storage folder on the local disk
-n|--nlog-extensions-folder
location of the nlog extensions on the local disk
-p|--securestore-plugins-folder
location of the securestore plugins on the local disk
-d|--dry-run
do not update the orchestrator app with the new values
-y|--accept-all
do not prompt for confirmation of actions and overwriting of files with kubectl cp.Usage: ./orchestrator_configurator.sh \
-c|--app-settings
-s|--storage-folder
-d|--dry-run
-y|--accept-all
do not prompt for confirmation of actions and overwriting of files with kubectl cp.To apply new application settings, run the following command:
./orchestrator_configurator.sh -c appsettings.json./orchestrator_configurator.sh -c appsettings.jsonIf the
appsettings.json file does not already exist, you can create it yourself, as shown in the following example:
"ExampleSetting.Enabled": true,
"ExampleSetting.Type": "BasicExample",
"ExampleSetting.Count": 3
}To change NLog configuration, run the following command:
./orchestrator_configurator.sh -l nlog.custom.json./orchestrator_configurator.sh -l nlog.custom.jsonExample nlog.custom.config
"Nlog": {
"targets": {
"robotElasticBuffer": {
"flushTimeout": 1000,
"bufferSize": 1000,
"slidingTimeout": false,
"target": {
"uri": "https://elastic.example.com:9200",
"requireAuth": true,
"username": "elastic-user",
"password": "elastic-password",
"index": "${event-properties:item=indexName}-${date:format=yyyy.MM}",
"documentType": "logEvent",
"includeAllProperties": true,
"layout": "${message}",
"excludedProperties": "agentSessionId,tenantId,indexName"
"Nlog": {
"targets": {
"bufferSize": 1000,
"target": {
