Last updated Sep 5, 2025
Cross-deployment feature comparison
This table compares the feature availability across the following deployment methods:
  • the AWS, Azure, and GCP cloud templates, which provision the infrastructure and install Automation Suite in a short amount of time. Templates are the recommended option.
  • the manual installation provisioning method, which requires more technical expertise and is considerably more time-consuming.
    Feature
    AWS template
    Azure template
    GCP template
    Manual installation provisioning
    Deploy to existing Virtual Network
    available
    available
    not available
    available
    Single-node evaluation vs. multi-node HA-ready production
    available
    available
    Can set number of instances
    available
    available
    Air-gapped
    not available
    not available
    not available
    available
    A-la-carte product selection
    available
    available
    available
    available
    Custom domain (cloud-provided DNS service or not)
    available
    available
    available
    available
    Custom certificates
    available
    available
    not available
    available
    Deploy to existing SQL Server
    not available
    available
    not available
    available
    Hardware requirements validation
    available
    available
    not available
    available
    Template uses cloud-native availability zones
    available
    available
    available
    N/A
    Proxy configuration
    not available
    not available
    not available
    available
    Optional bastion host
    available
    available
    not available
    N/A
    Instance refresh
    not available
    available
    not available
    N/A
    Backup and restore cluster
    available
    available
    not available
    N/A
    Remove nodes
    available
    available
    not available
    N/A
