- Overview
- Requirements
- Q&A: Deployment templates
- Configuring the machines
- Configuring the external objectstore
- Configuring an external Docker registry
- Configuring the load balancer
- Configuring the DNS
- Configuring Microsoft SQL Server
- Configuring the certificates
- Online multi-node HA-ready production installation
- Offline multi-node HA-ready production installation
- Disaster recovery - Installing the secondary cluster
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- GPU node affected by resource unavailability
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Issues accessing the ArgoCD read-only account
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- Exploring Logs
In a multi-node HA-ready production setup, High Availability (HA) is enabled by default. However, the Redis-based in-memory cache used by cluster services runs on a single node and represents a single point of failure. Therefore, if you have not purchased a High Availability Add-on (HAA) license, a cache node failure or restart will result in downtime for the entire cluster. To prevent such an incident, you can purchase HAA, which enables redundant, multi-node HA-ready production deployment of the cache.
All installations include the HAA software with a single-node license. This license is free of cost, no purchase required.
If you wish to enable HAA across multiple nodes, then purchasing an HAA license is required. This will implement full high availability for the cluster in a multi-node HA-ready production setup.
HAA is based on Redis technology.
To do that, take the following steps:
- Purchase an HAA license. Contact UiPath for details.
Update the following fields in the
cluster_config.jsonfile:fabric.redis.license- enter the HAA license converted to a single base64 string. In bash you can do that usingecho 'license_text_here' | base64 -w0.-
fabric.redis.ha- usetrueto enable HAA and make sure to also configure thefabric.redis.licenseparameter. This enables HAA database replication and increases the number of HAA pods to 3. By default,fabric.redis.hais set tofalse.Note: Ifredis.hais enabled,redis.licenseneeds to be set to a license that supports more than two shards."fabric": { "redis": { "ha": "true", "license": Base64String } }"fabric": { "redis": { "ha": "true", "license": Base64String } }
- Rerun the fabric installer:
Online installation
./install-uipath.sh -i cluster_config.json -f -o output.json --accept-license-agreement./install-uipath.sh -i cluster_config.json -f -o output.json --accept-license-agreement -
./install-uipath.sh -i cluster_config.json -f --install-type offline -o output.json --accept-license-agreement./install-uipath.sh -i cluster_config.json -f --install-type offline -o output.json --accept-license-agreement
