Last updated Dec 4, 2025
Step 2: Deploying Automation Suite to Azure
Once you have the Azure environment set up, navigate to this link to install Automation Suite in your Azure environment.
The following table provides an overview of the parameters used in the deployment:
Parameter name
Subscription
The Azure subscription.
Resource Group
The Azure Resource Group, under the subscription.
Resource Group Name
The name of the resource group where the cluster is deployed.
Region
The default region of the Resource Group.
Location
A valid Azure Region where the infrastructure is deployed. Make sure that the region has enough cores for the instance types used.
You can use the [resourceGroup().location] if this is the same as the Resource Group’s region.
Automation Suite version
The version of Automation Suite.
Example: 21.10.2
Run Automation Suite Install
Choose whether Automation Suite should be installed after the infrastructure is provisioned.
Accept License Agreement
By setting the parameter as true, you agree to the applicable license agreement.
DNS Load Balancer
The prefix used for the load balancer subdomain.
If you use a custom domain you will only be able to access the cluster through the custom domain, not directly using the load balancer's domain (eg. <prefix>.<region>.cloudapp.azure.com).
Virtual Network New Or Existing
Parameter indicating whether the Virtual Network used for the deployment should be created or if it already exists.
Existing Virtual Network Resource Group
Resource group where the existing Virtual Network you want to use is deployed.
Parameter used only if the Virtual Network New Or Existing parameter is set to existing.
Existing Virtual Network Name
Name of the existing Virtual Network used for deployment.
Existing Subnet Name
Name of an existing subnet inside the previously mentioned Virtual Network. The subnet must satisfy these requirements.
Deploy Bastion Host
Deploy a Bastion Host on the Virtual Network. Parameter used only if Virtual Network New Or Existing is set to new.
Enable Custom Domain
Set to true if you want to use your own custom domain. The needs post-install configuration.
Custom domain
This is the domain you want to use for the cluster. Post-installation, create two CNAME/A records that will point to the public load balancer. See DNS configuration.
Enable Custom Certificates
Set to true if you want to use your own custom certificates for your own domain. Make sure to use this together with the Enable Custom Domain parameter set to true.
Custom Server Certificate
This is a base64 encoded string.
Encode the contents of the .crt server certificate to a base64 string. The server certificate should have the following properties.
Custom Server Cert Key
Encode the contents of the .key server certificate key, to a base64 string. This is the private key from the Custom Server Certificate parameter.
Custom Server Cert Authority Bundle
Create a .crt file containing all public certificates (.crt) from all of the CA certificates in the Server Certificate chain (excluding the server certificate).
Create a base64 string from the contents of this file.
Automation Suite Installer URL
Optional: The link to the Automation Suite installation package.
Changing this parameter will overwrite the Automation Suite version parameter above and install the version specified in this URL.
Keep set to None if not used.
Automation Suite Advanced Config
This is a valid json string that will be merged in the cluster_config.json file that is being built by the template. Will overwrite existing settings.
Server Node Count
The number of VMs created to work as the servers for the cluster. Should be an odd number.
Server Node Instance Type
The instance type for the server nodes.
Example: Standard_D16s_v3
Server Node Hostname
Server node hostname/computer name prefix. For details on the appended sequence, see Azure documentation.
Enable Ultra Disks
Enable to use ultra disks for etcd (server nodes). Should only be disabled if the region you are deploying to does not have zones support.
Agent Node Count
The number of VMs created to serve as the agent nodes for the cluster. If 0, an empty agent scale set is still created.
Agent Node Instance Type
The instance type for the agent nodes.
Agent Node Hostname
Agent node hostname/computer name prefix. For details on the appended sequence, see Azure documentation.
Gpu Node Count
The number of VMs with GPU created to be the agents for the cluster. Designed for ML workloads. If 0, no GPU scale set is created.
Gpu Node Instance Type
The type of instances with GPU to be provisioned and to be the agents for the cluster.
Example: Standard_NC12s_v2
Gpu Node Hostname
GPU node hostname/computer name prefix. For details on the appended sequence, see Azure documentation.
Task Mining Node Type
Optional: Instance type of the task mining node. This will only be used if you enable the Task Mining service. Example: Standard_B20ms
Task Mining Node Hostname
Task Mining node hostname/computer name.
AS Robots Node Count
The number of dedicated Automation Suite Robots nodes. If 0, the scale set is still created.
AS Robots Node Instance Type
The instance type for the dedicated Automation Suite Robots nodes.
AS Robots Node Hostname
Automation Suite Robots node hostname/computer name prefix. For details on the appended sequence, see Azure documentation.
SQL new or existing
Parameter indicating whether the SQL Server used for the deployment should be created or it already exists. For SQL server requirements, see our documentation .
SQL Server FQDN or IP
FQDN or IP associated with the SQL Server. This is only used if the SQLNewOrExisting parameter is set to existing.
SQL Server Username
SQL Server user login. If the SQL new or existing parameter is set to existing, this is the user for the existing SQL server. Otherwise, this username will be set on the SQL server created. For details on the required permissions, see our documentation for permissions.
SQL Server Password
SQL Server user password. If the SQL new or existing parameter is set to existing, this is the user password for the existing SQL server. Otherwise, this password is set on the created SQL server.
SQL Server Port
SQL Server port. If the SQLNewOrExisting parameter is set to existing, this port is used.
WarehouseSQLServerFqdnOrIP
FQDN or IP associated with the Warehouse SQL Server. This is only used if the SQLNewOrExisting parameter is set to existing, and you want to install Process Mining.
WarehouseSQLServerUsername
Warehouse SQL Server user login. This is only used if you want to install Process Mining. If the SQLNewOrExisting parameter is set to existing, this is the user for the existing SQL server. Otherwise this username is set on the created SQL Server. For details on permissions, see Configuring Microsoft SQL server.
WarehouseSQLServerPassword
Warehouse SQL Server user password. This is only used if you want to install Process Mining. If the SQLNewOrExisting parameter is set to existing, this is the user password for the existing SQL server. Otherwise this password is set on the created SQL server.
WarehouseSQLServerPort
Warehouse SQL Server port. This is only used if you want to install Process Mining. If the SQLNewOrExisting parameter is set to existing, this port is used.
UiPath Admin Username
The admin username to be set on all nodes. This is also used as the host tenant admin.
UiPath Admin Password
The password for the node admin user. This is also used as the host tenant admin password.
Vm Admin Username
The admin username to be used in the virtual machine instances.
Vm Admin Password
The admin password to be used in the virtual machine instances.
Enable Cluster Backup
Set to true if you want to deploy the external NFS file share. Also, the backup will be enabled at cluster level if the Run Automation Suite Install parameter is set to true.
Services Install flags (multiple)
Choose if the specific service is installed in the cluster.
externalRegistryFQDNThe external registry FQDN.
externalRegistryUsernameThe external registry username.
externalRegistryPasswordThe external registry password.
AI Center Connect To External Orchestrator Flag
Flag which determines whether AI Center connects to an external Orchestrator. Only works if AiCenterInstallFlag is set to 'true'. You need to specify how AI Center connects to the Orchestrator in the following parameters.
OrchestratorUrl
The URL for Orchestrator to which AI Center connects. Fill this in only if you want to install AI Center and connect it to an external Orchestrator and Identity Service.
IdentityUrl
The URL for the Identity Service to which AI Center connects. Fill this in only if you want to install AI Center and connect it to an external Orchestrator and Identity Service.
OrchestratorCertficate
The Certificate in Base64 for the Orchestrator to which AI Center connects. Fill this in only if you want to install AI Center and connect it to an external Orchestrator and Identity Service.
IdentityCertificate
The Certificate in Base64 for the Identity Service to which AI Center connects. Fill this in only if you want to install AI Center and connect it to an external Orchestrator and Identity Service.
Tags by resource
Optional: Tags per resource. Can be empty or have the following format:
{ "Microsoft.Web/serverFarms": { "<TagName>": "<TagValue>" }, "Microsoft.Insights/components": { "<TagName>": "<TagValue>" } }
