- Overview
- Requirements
- Q&A: Deployment templates
- Configuring the machines
- Configuring the external objectstore
- Configuring an external Docker registry
- Configuring the load balancer
- Configuring the DNS
- Configuring Microsoft SQL Server
- Configuring the certificates
- Online multi-node HA-ready production installation
- Offline multi-node HA-ready production installation
- Disaster recovery - Installing the secondary cluster
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- GPU node affected by resource unavailability
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Issues accessing the ArgoCD read-only account
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- Exploring Logs
AI Center considerations
linkOn top of the core service requirements that are part of full platform requirements, AI Center requires additional resources, depending on the models that you want to run or train. For more details about the required GPU hardware generations and compatible NVIDIA drivers, refer to Compatibility Matrix.
In this table, Data Disk is needed on all server nodes. This is not needed on agent nodes.
Use |
CPU |
RAM (GB) |
GPU |
Disk (GB) |
Minimum for serving (ML Skill, one replica) |
0.6 |
2 |
0 |
Minimum for Training (Pipeline) |
1 |
4 |
0 |
DU model Serving (ML Skill, one replica) |
1 |
4 |
0 |
DU model Training |
2 |
24 |
Strongly recommended |
Use |
CPU |
RAM (GB) |
GPU |
Disk (GB) |
Small implementation:
4 |
32 |
0 |
Average implementation:
8 |
52 |
rancher
partition = 80 GB on the rancher
partition
2 1 pipeline * 105GB = 105 Data disk
rancher
partition = 160 GB on the rancher
partition
4 (2 pipeline + 1 DU pipeline) * 105GB = 315 Data disk
