2022.4
Last updated Mar 17, 2025
Step 5: Updating the migrated product connection strings
Generating the cluster_config.json file
Generate the latest cluster_config.json file as follows:
  • Option A: If you have the old cluster_config.json, generate the configuration file from the cluster by running the following command on the server node:
    cd /opt/UiPathAutomationSuite/{version}/installer
    ./configureUiPathAS.sh config get -i /path/to/old/cluster_config.json -o ./cluster_config.jsoncd /opt/UiPathAutomationSuite/{version}/installer
  • Option B: If you do not have the old cluster_config.json file, generate an override of any default values resulted during the installation of the previous version by running the following command on the server node:
    ./configureUiPathAS.sh config get -o ./cluster_config.jsoncd /opt/UiPathAutomationSuite/{version}/installer
Note:
For details on how to configure the cluster_config.json parameters, see Advanced installation experience.
Step 5.2: Providing the new connection strings for installed products
You must provide the database connection string to the restored databases.
  • To provide the restored connection string to the Orchestrator service, add or update sql_connection_str under orchestrator in the cluster_config.json file:
    "orchestrator": {
      "sql_connection_str": "<dotnet connection string>",   (added line)
      "enabled": true
    }"orchestrator": {
      "enabled": true
  • If Test Automation tables are placed inside the standalone Orchestrator database, you can add the same connection string for Test Automation feature inside the cluster_config.json file:
    "orchestrator": {
        "testautomation": {
          "enabled": true,
          "sql_connection_str": "<restored orchesrator connection string>"
      "sql_connection_str": "<restored orchesrator connection string>",   (added line)
      "enabled": true
    }"orchestrator": {
        "testautomation": {
          "enabled": true,
      "enabled": true
  • To provide the restored connection string to the Insights service, add or update sql_connection_str under insights in the cluster_config.json file.
    "insights": {
       "sql_connection_str": "<restored connection string>",   (added line)
       "enabled": true }"insights": {
       "enabled": true }
Note: Make sure you escape special characters in the connection string's password.
Step 5.3: Running the service installer
Online
To run the service installer in an online environment, run the following command on the server node:
./install-uipath.sh -i ./cluster_config.json -s -o output.json --accept-license-agreementcd /opt/UiPathAutomationSuite/{version}/installer
Offline
To run the service installer in an offline environment, use the following command on the server node:
./install-uipath.sh -i ./cluster_config.json -s --install-type offline -o output.json --accept-license-agreementcd /opt/UiPathAutomationSuite/{version}/installer
  • Generating the cluster_config.json file
  • Step 5.2: Providing the new connection strings for installed products
  • Step 5.3: Running the service installer
  • Online
  • Offline
