2022.4
- Overview
- Requirements
- Cluster administration
- Managing products
- Managing the cluster in ArgoCD
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- B) Single tenant migration
- Installation best practices
- Performing database maintenance
- Performing yearly certificate maintenance
- Setting up directory roles and permissions
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- RKE2 fails during installation and upgrade
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Exploring Logs
Last updated Mar 17, 2025
To grant permissions to a specific admin or regular user to access the Kubernetes cluster and RKE2 file, you must update the
sudoers file with the required settings.
The following section provides details on the files to which you must grant access to the admin or regular user.
/var/lib/rancher/rke2/bin/kubectlexecutable requires sudo access to operate on cluster resources. To grant the required permissions to the executable without a password, update thesudoersfile accordingly. For details, see the following configuration sample:USERNAME ALL = NOPASSWD: /var/lib/rancher/rke2/bin/kubectlUSERNAME ALL = NOPASSWD: /var/lib/rancher/rke2/bin/kubectl /etc/rancher/rke2/stores the following files required to configure or access the cluster:-
/etc/rancher/rke2/config.yamlfile used to configure the cluster. The default permission for this file is-rw-r--r--. To allow users to modify/etc/rancher/rke2/config.yaml, update thesudoersfile accordingly. For details, see the following configuration sample:USERNAME ALL=NOPASSWD: /usr/local/bin/vim /etc/rancher/rke2/config.yamlUSERNAME ALL=NOPASSWD: /usr/local/bin/vim /etc/rancher/rke2/config.yaml -
/etc/rancher/rke2/rke2.yamlfile used along with thekubectlcommand to operate on the cluster. The default permission for this file is-rw-------.To allow users to operate on the cluster, update thesudoersfile accordingly. For details, see the following configuration sample:Defaults!/var/lib/rancher/rke2/bin/kubectl env_keep += KUBECONFIGDefaults!/var/lib/rancher/rke2/bin/kubectl env_keep += KUBECONFIG -
/etc/rancher/rke2/registries.yamlfile required to configure the registry for the cluster. The default permission for this file is-rw-r--r--.To allow users to modify/etc/rancher/rke2/registries.yaml, update thesudoersfile accordingly. For details, see the following configuration sample:USERNAME ALL=NOPASSWD: /usr/local/bin/vim /etc/rancher/rke2/registries.yamlUSERNAME ALL=NOPASSWD: /usr/local/bin/vim /etc/rancher/rke2/registries.yaml
/var/lib/rancher/rke2/directory stores the cluster related data, which includes kubelet logs, containerized data, static pod configuration files, RKE2 certificates, and etcd data. Admins may be required to read the file and check the size of the directory. To do this, you must give the required permissions to thels,cat, andducommands. For details, see the following configuration sample:USERNAME ALL=NOPASSWD: /usr/bin/ls /var/lib/rancher/rke2/* USERNAME ALL=NOPASSWD: /usr/bin/cat /var/lib/rancher/rke2/* USERNAME ALL=NOPASSWD: /usr/bin/du /var/lib/rancher/rke2/*USERNAME ALL=NOPASSWD: /usr/bin/ls /var/lib/rancher/rke2/* USERNAME ALL=NOPASSWD: /usr/bin/cat /var/lib/rancher/rke2/* USERNAME ALL=NOPASSWD: /usr/bin/du /var/lib/rancher/rke2/*
Note:
For maintenance purposes, we recommend creating a separate file under the
/etc/sudoers.d/ directory with the configuration described on this page.
