2022.4
- Overview
- Requirements
- Cluster administration
- Managing products
- Managing the cluster in ArgoCD
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- B) Single tenant migration
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- RKE2 fails during installation and upgrade
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Exploring Logs
Last updated Mar 17, 2025
linkCleaning up Ceph logs
linkMoving Ceph out of read-only mode
If you installed AI Center and use Ceph storage, take the following steps to move Ceph out of read-only mode:
- Check if Ceph is at full capacity:If Ceph is at full capacity, you must adjust the read-only threshold to start up the rgw gateways.
kubectl -n rook-ceph exec -it deploy/rook-ceph-tools -- ceph status
kubectl -n rook-ceph exec -it deploy/rook-ceph-tools -- ceph status - Scale down the ML skills:
kubectl -n uipath scale deployment <skill> --replicas=0
kubectl -n uipath scale deployment <skill> --replicas=0 - Put the cluster in write mode:
ceph osd set-full-ratio 0.95 <95 is the default value so you could increase to 96 and go up incrementall>
ceph osd set-full-ratio 0.95 <95 is the default value so you could increase to 96 and go up incrementall> - Run Garbage Collection:
kubectl -n rook-ceph exec -it deploy/rook-ceph-tools -- radosgw-admin gc process --include-all
kubectl -n rook-ceph exec -it deploy/rook-ceph-tools -- radosgw-admin gc process --include-all - When storage goes down, run the following commands:
kubectl -n rook-ceph exec -it deploy/rook-ceph-tools -- ceph status kubectl -n rook-ceph exec -it deploy/rook-ceph-tools -- ceph df
kubectl -n rook-ceph exec -it deploy/rook-ceph-tools -- ceph status kubectl -n rook-ceph exec -it deploy/rook-ceph-tools -- ceph dfAt this point, the storage should be lower, and the cluster should be healthy.
Disabling streaming logs
To ensure everything is in a good state, disable streaming logs by taking the following steps.
- Disable aut-sync on UiPath and AI Center.
- Disable streaming logs for AI Center.
- If you have ML skills that have already been deployed, run the following commands:
kubectl set env deployment [REPLICASET_NAME] LOGS_STREAMING_ENABLED=false
kubectl set env deployment [REPLICASET_NAME] LOGS_STREAMING_ENABLED=false - Find out which buckets use the most space:
kubectl -n rook-ceph exec deploy/rook-ceph-tools -- radosgw-admin bucket stats | jq -r '["BucketName","NoOfObjects","SizeInKB"], ["--------------------","------","------"], (.[] | [.bucket, .usage."rgw.main"."num_objects", .usage."rgw.main".size_kb_actual]) | @tsv' | column -ts $'\t'
kubectl -n rook-ceph exec deploy/rook-ceph-tools -- radosgw-admin bucket stats | jq -r '["BucketName","NoOfObjects","SizeInKB"], ["--------------------","------","------"], (.[] | [.bucket, .usage."rgw.main"."num_objects", .usage."rgw.main".size_kb_actual]) | @tsv' | column -ts $'\t' - Install s3cmd to prepare for cleaning up the
sf-logs
:pip3 install awscli s3cmd export PATH=/usr/local/bin:$PATH
pip3 install awscli s3cmd export PATH=/usr/local/bin:$PATH - Clean up the
sf-logs
logs. For details, see How to clean up old logs stored in the sf-logs bundle. - Complete the cleanup operation:
kubectl -n rook-ceph exec -it deploy/rook-ceph-tools -- radosgw-admin gc process --include-all - If the previous steps do not solve the issue, clean up the AI Center data.
- Check if the storage was reduced:
kubectl -n rook-ceph exec -it deploy/rook-ceph-tools -- ceph df - Once storage is no longer full, reduce the backfill setting:
kubectl -n rook-ceph exec -it deploy/rook-ceph-tools -- ceph osd set-full-ratio 0.95
kubectl -n rook-ceph exec -it deploy/rook-ceph-tools -- ceph osd set-full-ratio 0.95 - Check if the ML skills are affected by the multipart upload issue:
echo $(kubectl -n rook-ceph exec deploy/rook-ceph-tools -- radosgw-admin bucket list --max-entries 10000000 --bucket train-data | jq '[.[] | select (.name | contains("_multipart")) | .meta.size] | add') | numfmt --to=iec-i
echo $(kubectl -n rook-ceph exec deploy/rook-ceph-tools -- radosgw-admin bucket list --max-entries 10000000 --bucket train-data | jq '[.[] | select (.name | contains("_multipart")) | .meta.size] | add') | numfmt --to=iec-iIf they are affected by this issue, and the returned value is high, you may need to do a backup and restore.
